Question about Panasonic VIERA TH-65PV500 65 in. Plasma Television
Television turned itself off and won't come back on again
Please can you help. I am in Australia so I don't know if our TV set up is the same as yours. The actual product is a Panasonic Plasma TV VIERA TH-50PX70A, your list doesn't recognise this model. Anyway the problem is this.
We were watching a film on Foxtel (equivalent to SKY etc) and the TV turned itself off and could not be turned back on again. It seem to go into Standby mode. The red light on the TV near the on button flashes on and off when you push the remote control on/off button. When you turn the TV off at the main switch and then push it on again, the TV clicks like it is going to come on the light goes green, then immediately goes red and the TV doesn't do anything. No picture, No sound.
We have only had this for a couple of weeks and the manual doesn't give any idea as to what the problem could be or how to solve it.
Thank you for your help, regards Tracey.
  • 1 more comment
  • Linenlady Oct 29, 2007
    Thanks we will try those suggestions
    Linenlady
    Tracy
  • Anonymous Jun 21, 2008
    our tele turned itself off for a moment and came back on in standby mode . when we try to turn it on via the remote it just clicke and stays in standby mode?
  • ashimas Aug 29, 2008
    I am facing the same problem, please let me know if this problem was rectified and how.
    I have tried switching it off and on again after removing the power cord for good 30 minutes.
    Thanks in advance,
    Sarah
Tracy it sounds like a power supply problem, not anything you have done.This day and age the new electronics are only built for min running requirement, as in the working capacity of the power supply.Not like a few years ago when things where built to last and some still do.
It has a standby mode thats why most things have a led to show you if its on or off.This only come about for some reasons and that was to keep the old Tube Type Teleivision warm so you have instant picture, if you have turned this type of teleivision off at the wall it would take a few minutes to get a lets say a stable picture.
Enough of showing my age.
But this means the the powersupply is only in sleep mode only and uses bare min, to run and when you push the power on button you have life and then your picture.
Try this if and when it comes on and stays on, then it goes off on you, turn it off from at the wall and leave it for 5-10 min and try again, if it comes alive its a heat problem in the supply and maybe a dry joint which needs to be looked at.
If it does not try turning off and on at the set not at the remote, it could be the remote section is not working properly and have the same sort of fault. If you think it could be in the set up, try your sleep mode set up, it could be turned on, so check if the TV goes off at the same time say 5 min's everytime??
If it's the first fault you will have to get it back under warranty very quickly, these are inherent problems, companies want the dollar and not so much the quaility you get....
I hope I have helped???
P.s. if its the type where you have a power lead that plugs into the set and the wall Check that too, I have fixed many of things because the moulded lead has let the pins inside them open up..
Think basic first ok!
Posted on Oct 29, 2007
Power fuse supply
Have you checked to see if you have a sleep setting that may have got inadvertantly set?
Sep 26, 2013 | AOC Envision L27W461 27 in. HDTV LCD...
Sony Bravia LCD tv model KDL40S4100 won't hold settings.
What you've heard is right. This is a main system control memory IC fault itself.
Jun 19, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
Tv remains on for about 20 minutes then shuts off by itself and won't come back on. please help
does the power indicator blink when the set shuts down? If so thats an error code let me know the number of blinks and I will assist with the reason why the set is shutting down.
Jan 20, 2012 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
WS-65511 won't turn on
Hello
The power supply section to your set has the fault. If you come over me by Fixya paid service purchase, I'll assist you to repair your tV by yourself at home. OK.
Dec 07, 2011 | Mitsubishi WS-65511 65" Rear Projection...
Won't program to our new TCL television - we have the 222 receiver
I don't show we have a code for the TCL (Australia) brand TV. Below I have provided instructions on how to perform a power scan.
  • Remote: Basic Remote (Television Only)
    1. Turn the Television On.
    2. Press and hold the clear TV button for three seconds until the LED flashes.
    3. Press and release the red TV Power button.
    4. Press and release the Up or Down Arrow on the remote until the television turns off.
    5. After the television turns off, press and release the # button.
    6. Test functionality with the TV.
    7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Aug 14, 2011 | DISH Network IR Remote Control
My panasonic th-50px60u television turned itself off last night and won't turn on makes clicking noise when unplugged and plugged back in but then nothing red light flashes
Tries tv unplug,replug it back like about an hour later for the tv to do it resetting itself back to the factory setting,tv might work again.If not still same problems.The tv 90-95% it is the board that call the tv power supply board is having a problems.That the board where the tv power a/c cord plug into it.U have all tools and know basic electronic and also can do basic soldering works too?Yes,take the tv aparts,check the tv power supply board carefully for dying and soon to be dead capacitors components parts.These capacitors components parts are alway bulges up or puffing up onto it tops.These dying and soon to be dead capacitors components parts are bulges or puffing ups on to it tops must have to be replaced will solved ur tv power unstable and flashing red light.Or try website like Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Jul 29, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Hi. My playstation won't work at all. When i try to turn it on, it goes on sometimes on the tv, or else, it says that i don't have connection from the PS3 to my tv.. I Checked my HDMI, and...
If the screen is just black and the PS3 doesn't turn itself off, then it could just be that the video settings don't go out through the correct output. This will reset the video output:
  • Hold the power button for 5-10 seconds until you hear two beeps; then let go
May 31, 2011 | Sony Playstation 3 (PS3) Console
Ive just bought this tv and when i turn it on the stand by light is flashing but i cant turn the tv on please can you help?
This shouldn't happen. When the standby light is flashing there is a problem with the television and it needs servicing. It could be the main board, the power supply, or both. This is a costly repair when a television is not in warranty. Now there are times when a television has to be turned on from the power button located on the top or side of it when first being unboxed. At a time like that the remote control will not work to power on the television. I don't believe that is the problem you are experiencing.
The troubleshooting for this is to unplug the television overnight and when you plug it back in the next day wait for the standby light to start flashing. Hold down the power button on the television set itself. Wait and see if the standby light stops flashing and turns red (or a different color). Let go of the power button. Press it once more and release it once more. The television should come on.
Even if the above works you don't want to risk something really being wrong with the television and a costly repair being needed after the warranty expires.
May 14, 2011 | Televison & Video
My Insignia tv keeps defauting to Video1 screen every minute!!!
Turn off your television. Try disconnecting all external signal sources (except the antenna or cable) from your television.Turn on the television and see if this resolves the problem. If it does then you may have a faulty cable connection to your television. Change out the cables one by one to find the bad cable and replace it. If this does not solve your problem. Turn off for a period of hours(This may allow your television set to reset itself) and test again. If you still have the same problem, Then you need to call customer service for servicing and technical advise. Call this number for service : 1-877-467-4289. Hope this helps you with your problem.
Apr 07, 2009 | Insignia LCDTV26 26 in. Television
Panasonic VIERA TH-65PV500 65 in. Plasma Television Logo
412 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
