Fax b120 Hi, following instructions in manual for auto receive fax, but stays on net sw... what is net sw, cant work it out, ready to chuck it in the tip...Regards Steve
  • 1,113 Answers
Net sw is network switch and is used in Oz and N.Z. to reconise Telstra Duet System, should work anyway just ringa little different, if you press receive mode button,setting should cycle everytime you press it and will lock to any setting displayed if you press start. sounds like you want "fax only"
page 65 user manual speaks of it
http://apparat.conagri.se/pdm/50524Canon_FAX-B115-120-140_enbr.pdf
Posted on Oct 29, 2007
How do i change from manual receive mode to auto?
You want "Fax/Tel" Mode. To do this follow instructions below.
To set a receive mode follow the instructions below.
a Press Menu.
b Press a or b to choose Initial Setup.
Press OK.
c Press a or b to choose Receive Mode.
Press OK.
d Press a or b to choose Fax Only, Fax/Tel, External TAD or Manual.
Press OK.
e Press Stop/Exit.
The LCD will display the current receive mode.
Apr 04, 2011 | Brother MFC-465CN InkJet Printer
Hp officejet 6500 instructions for receiving a fax? Thanks
You can receive faxes automatically or manually. If you turn off the Auto Answer option, you must receive faxes manually. If you turn on the Auto Answer option (the default setting), the device automatically answers incoming calls and receives faxes after the number of rings that are specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings.)
If you receive a legal-size fax and the device is not currently set to use legal-size paper, the device reduces the fax so that it fits on the paper that is loaded. If you have disabled the Automatic Reduction feature, the device prints the fax on two pages.
NOTE: If you are copying a document when a fax arrives, the fax is stored in the
device memory until the copying finishes. This can reduce the number of fax pages stored in memory.
This section contains the following topics:
• Receive a fax manually
• Set up backup fax reception
• Reprint received faxes from memory
• Poll to receive a fax
• Forward faxes to another number
• Set the paper size for received faxes
• Set automatic reduction for incoming faxes
• Block junk fax numbers
• Receive faxes to your computer (Fax to PC and Fax to Mac)
When you are on the phone, the person you are speaking with can send you a fax while you are still connected. This is referred to as manual faxing. Use the instructions in this section to receive a manual fax.
NOTE: You can pick up the handset to talk or listen for fax tones.
You can receive faxes manually from a phone that is:
• Directly connected to the device (on the 2-EXT port)
• On the same phone line, but not directly connected to the device
NOTE: The automatic document feeder must be empty to receive a fax. If there are documents in the ADF, then the device will not be able to receive incoming faxes.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the input tray.
2. Remove any originals from the document feeder tray.
are documents in the document feeder, then receiving the fax will be
unsuccessful.
3. Do one of the following to answer a fax manually:
• Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers.
• Turn off the Auto Answer setting so that the device does not automatically
answer incoming calls.
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press START FAX Black or START FAX Color on the device control panel.
b. When prompted, select Fax Receive.
NOTE: Depending on your country/region, the device might receive the fax
automatically when you hear fax tones from the sending fax machine.
6. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Jan 30, 2011 | HP 1250 Plain Paper Thermal Inkjet Fax
How do I set up the fax feature?
Introduction The HP All-in-One can receive faxes automatically or manually depending on the Auto Answer setting. If the Auto Answer option is set to On (the default setting), the HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Refer to the given instructions to receive faxes automatically or manually. Receiving faxes The HP All-in-One can receive faxes automatically or manually. Receiving a fax automatically To receive faxes automatically, set the Auto Answer option to On (the default setting). The HP All-in-One will automatically answer incoming calls and receive faxes after the number of rings specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings). Receiving a fax manually If the HP All-in-One has been set up to receive faxes manually (the Auto Answer option is set to Off ), or you answer the phone and hear fax tones, use these instructions to receive faxes.
  1. Make sure the HP All-in-One is turned on and you have paper loaded in the input tray.
  3. Set the Rings to Answer setting to a high number to allow you to answer the incoming call before the HP All-in-One answers. Or, turn off the Auto Answer setting so that the HP All-in-One does not automatically answer incoming calls.
    1. Press Start Fax Black or Start Fax Color on the control panel of the HP All-in- One.
    2. When prompted, press the down arrow to highlight Receive Fax Manually , and then press OK .
  6. Press Start Fax Black again.
  7. After the HP All-in-One begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
    Trust this is helpful. Please vote. :)
Dec 11, 2010 | HP Photosmart C7280 Laser Printer
Recieve mode
Hi slickkitty
Only one press for each display,
When you press the FAX RECEIVE MODE button, the display should change each time you press. eg: AUTO, FAX ONLY
When you see the FAX ONLY, press the SET button and leave it like that. Don't try to do it when the fax rings. Do it when the fax machine is idle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The following instruction is found in your Fax Manual.
Set the fax machine to FAX ONLY mode by
pressing {RECEIVE MODE} until the
following is displayed.
1 The display will show the number of
rings before the fax machine answers a
call in FAX ONLY mode.
2 Press {+} or {-} to change the ring
setting to 2 and press {SET}.
How to receive calls
Just leave it. When the other party sends a fax,
the fax machine will receive it automatically.
Hope this will help, if it helped you, please give a rating.
Good luck
luciana44
Sep 19, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
Not receiving faxes. It will send but not receive
have someone send you a fax. When the machine rings, press START. if this works you are set to MANUAL instead of AUTO
Sep 17, 2009 | Brother IntelliFAX 5750e Laser Fax
Can not recieve fax. currently just hooked to phone line
Receive a fax
Depending on the Auto Answer setting, your HP All-in-One can receive faxes
automatically or manually. If you have set the Auto Answer option to Off, you will
need to receive faxes manually. If the Auto Answer option is set to On (the default
setting), your HP All-in-One will automatically answer incoming calls and receive faxes
If you set up your HP All-in-One to receive faxes manually (the Auto Answer option is
set to Off) or you answer the phone and hear fax tones,
tray.
3. If you are currently on the phone with the sender, instruct the sender to press
4. When you hear fax tones from a sending fax machine, do the following:
a. Press Fax on the control panel of your HP All-in-One.
b. When prompted, press 2 to select Receive fax.
c. After the HP All-in-One begins to receive the fax, you can hang up the phone.
Jan 14, 2009 | HP Officejet 5610 All-In-One InkJet...
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Can not receive fax
Make sure the fax is set to receive automatically. The receive mode must be set to one of the following modes: Fax Only, Fax/Tel Auto Sw, or Ans Machine. If it is set for Answering Machine, be sure the machine is connected to the fax, turned on, and contains a recorded outgoing message.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jun 24, 2008 | Canon FAX-JX200
Not receive
I'm not familiar with the B120, but if you have an L120 the manuals are available here. The Starter Guide will explain receive mode options and setup instructions. The Advanced Guide will provide troubleshooting guidance.
Apr 16, 2008 | Canon PC-1080F Plain Paper Laser Fax
Hp T65 program to receive faxes
press setup and change the following settings
basic fax settings:
1. auto answer : ON
2. Rings to answer = 3 rings (recommended)
Advanced fax settings:
1. distinctive ring pattern = all rings
2. ECM = OFF
3. Fax speed = slow
Feb 02, 2008 | HP OfficeJet t65 All-In-One InkJet Printer
124 people viewed this question
k24674
jasbo
jasbo
