Fuji DOCUPRINT 340A Laser Printer Logo
n
nufalala Posted on Feb 20, 2014
Printer reboot (010-3459) - Fuji DOCUPRINT 340A Laser Printer
9helpful
2answers
Please reboot printer (124-315)
How to reboot printer Xerox DocuPrint C4350 error code : printer (124-315)
Scanner attachment failure
Disconnect the printer, and reboot the PC, and after rebooting, shut it down again and now attach the printer and reboot the PC, and it should work fine.
How do i reboot a hp d 7360 printer
Unplug from wall socket for 10 min, plug back in reboot.
1helpful
Inializing forever
this problem is usually caused by an eio card in the printer, ( jet direct card or hard disk), first thing to do is to remove these cards and reboot with only the power cable connected to the printer, once this reboots if the printer reaches a ready state print a test page directly from the printer, if this prints fine, then the actual printer hardware is fine, then it is a matter of rebooting with the jet direct installed, if the printer hangs problem with the card needs replaced, if this works fine, them do the same thing with the hard disk,
SHARP AL-2040CS offline after reboot
Official Sharp driver had set "use printer offline" setting in the printer properties context menu. After unselecting the "use printer offline", printer is printing again, even after reboot...
Computer won't communicate with printer
Make sure that the printer driver you are using is compatible with your version of windows. If so, open all printers in "control panel" and make sure that this printer is the preferred printer and not an old one you might still have installed.
Hpdeskjet f380 printer
With most printer you have to install the drivers and software before plugging in the printer. if you have not tried this unplug your printer and uninstall all software and drivers from your pc. reboot and install drivers then it should ask during install to plug printer in, if not wait until all drivers and software has finished and reboot again. wait ten minutes after reboot then plug printer in, it should then find its software. Hope this helps
1helpful
PIXMA iP1880 ink cartridge not properly installed....
one solution is turn off your printer, and reboot your system, after rebooting, turn on your printer again. If that doesn't work try re-installing the printer drivers be sure to turn off the printer and reboot the system afterwards to refresh the system.
Hope this was helpful:)
Printer reboots computer
yeppers..
remove the existing software for printer
go to www.epson.com and get fresh drivers
install them
try it again
Dont know much about computers...
On Windows XP, start/control panel/add or remove programs/find your printer software/click on change/remove and remove.
Reboot.
start/printers & faxes/find your printer/right click on it/delete
unplug the printer
Reboot
once the pc has rebooted, plug in the printer. Windows should find the printer and ask for a driver. Insert your software CD and try again!
Top Fuji Office Equipment & Supplies Experts
Jose Ramirez
john h
ADMIN Andrew
ADMIN Andrew
Are you a Fuji Office Equipment and Supply Expert? Answer questions, earn points and help others
