I need a unlock code for a Samsung Galaxy s3 Phone Model number SCH-I535 I carrier I got the phone from will not give me the code
You can purchase such code from any vendors online and you can also have a lookup at this free guide
MobileUnlockGuide.com
SOURCE: I NEED A UNLOCK CODE FOR MY SAMSUNG SCH-a870
To unlock your Samsung SGH600 mobile here is a code *2767*3855# it will reset eprom.which removes SP lock.
For A series samsung the unlock code is
*2767*637#.this code reset your mobile.
SOURCE: changed nam on phone that changed lock code,need unlock code
when phone turns on it probably says something in the way of needs initial set up or something simular? at that screen just hit clear button which will take you rt back to default screen then hit center menu button go to settings and then to phone settings,nam and chaNGE back to nam1,hit ok . phone will restart and come back on with everything normal again,let me know if different happens!
SOURCE: samsung sch-r450, i need the 4-digit code to
try dialing #43574357* it should show you the sid meid min etc. make sure you write down SID. then go to settings from the main menu>press *>587846. in the MIN and MDN field put in 10 digit phone number and put in SID exactly the same as you wrote it down so if 0 is the first number be sure to put 0 and the rest of the numbers. the phone will reset and your phone WILL work
