Hand Tools Logo
b
byron brown Posted on Dec 20, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blade installation Hi. I have a couple of question to ask. Have you install anything like changeable/replaceable blades in a sheet FAB FINN Power machinery. meaning if one blade goes out instead of maintenance comes out to change the blade you can switch to another. Do your do that and if you do which companies have those devices.
Bill Boyd
Level 3:
Top Expert:
  • Master 53,816 Answers
  • Posted on Dec 20, 2017
Bill Boyd
Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11948915
Points
172802
Noty a question for fixya site
get the correct manufacturers site up and ask them
3 Related Answers
Anonymous
  • 75 Answers
  • Posted on Apr 26, 2009
SOURCE: need to change saw blade, lost instructions
1st, !!UNPLUG the saw!! Wear gloves to prevent nicks from contact with the saw blades.
If this is a handheld 'skill-saw' type saw, use a piece of wood to chock the saw blade from turning as you use a proper size socket/wrench to loosen the bolt which holds the blade.
The bolt will loosen counter-clock wise. It will probably be very tight, and you will have to use some effort to loosen it.
Remove the bolt, lift the follow guard and remove the blade.
Replace the blade with a like size diameter blade by raising the follow guard, inserting the blade, replacing the bolt, using a piece of wood to keep the blade from rotating and TIGHTEN the bolt. You will almost feel as if you need three hands to accomplish this procedure but its been done millions of successful times.
Good luck. :)
David Shaub
  • 2994 Answers
  • Posted on Aug 09, 2009
SOURCE: How do you replace a 9596 Fiskars paper trimmer blade carriage?
Take it to the middle and flex the slot open.
K W
  • 509 Answers
  • Posted on Feb 11, 2010
SOURCE: How to install new blade in buck Bros keyhole saw
There is a slot at the back of the blade. Bent the blade out enough to clear the notch in the handle and fold the blade down.
How to replace blades on a hand held power devil planer (old version)
Try this.
Loosen the fastening bolts Loosen the three bolts that secure the blade.
2. Remove the blade
Now you can use a screwdriver to begin sliding the blade out of its slot. Grab the blade carefully and slide it out the rest of the way.
3. Repeat the process on the reverse side
Now turn the planer's drum around to the other side and repeat the process on the second blade.
4. Install the new blade
Now you can install the new blades. Notice the blades have a notch on them that aligns with the slot on the drum. Align the notch and slide the blade into place.
Loosely tighten the outer two nuts, but don't tighten them completely yet.
5. Align the blade
Make sure the blade is centered so it won't rub against either side of the planer. Once the blade is centered you can fasten the bolts down completely.
6. Repeat the process on the reverse side
Now rotate the drum and install the new blade on the other side.
Wiper blades need replacing
Every car has a different procedure for installation. Buy your wiper blades at your auto parts store and they will install them for free, if you ask them to.
Need fan blade-to-motor bracket as mine has broken and can't seem to repair!!!
Most home centers that sell ceiling fans carry replacement Fab Blade Irons (that's what you're looking for).Try Lowe's or Home Depot.
How do you change the windshield wiper blades
Most replacement blades come with good instructions. I believe most Toyotas use the J-hook style arm. If you are not sure, go to a car parts store and ask for help, they may explain it to you or even show you how and install them for you. Really simple after you have done it a couple of times.
REPLACING A RIDING MOWER BELT BLADE
Hello. REmove the deck from your mower so you can easily get at the belt and the blade. Make a drawing of how the belt is installed so you can install the new one the same way, loosen the idler pulley and remove the belt. Generally you have to remove a couple of parts to get the old belt off in one piece and get the new one on. You will need a set of socket wrences. To replace the blade use a block of wood to hold the old blade stationary and a large socket wrench to loosen the nut holding the blade in place.
Nov 25, 2009 • Garden
11helpful
Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
4helpful
Replacing lawnmower blades on 38 inch yardman
Need to plug spark plug [for safty]. Install 2x4 blocking between blade and chassy,use clamps.Coat threaded area with wd 40 and torque in clockwise position,not counterclockwise to remove old blade and install new turning bolt counterclockwise or [unscrewing direction].
Please rate. Thanks jj505
4helpful
2answers
Where do I get new blades for my Household Blending Mixer HA-3058
It seems you can no longer buy the MegaMixa HA-3058 however Bamix sell a similar product - in fact apart from a couple of aesthetic modifications it seems to be the same machine....
They sell many accessories and you can get blades. Check:
www.bamix.com
www.bamix-blender.co.uk
I have both machines and the blades are identical and inter-changeable between models.
Feb 23, 2009 • Food Mixers
I have the alpha 8554. I dont like the plastic combs, is that the only way to adjust closeness?
No, the type of blade you have can be adjusted or change to a closer type blade. This blade is inter-changeable but you need a special tool to restt the blade or change the blade for the type of hair cutting you want.
Call Mannys Sharpening 323 263-4697
Top Hand Tools Experts
john h
Larry Ng
Larry Ng
Ziyaad Khan
Ziyaad Khan
Level 1 Expert
Are you a Hand Tool Expert? Answer questions, earn points and help others
