Question about Sony Handycam HDR-HC3 HDV Digital Camcorder
Sony HDR_HC3 Problem code c:32:60 "reattach power source"
Have a Sony HDR-HC3. Came in from the cold and tried to use camera. It keeps saying to re-attach the power source. Won't focus and the error code C:32:60 comes up in the corner of view screen and it beeps. Tried re-attaching battery and resetting reset button. Let the camera warm up inside , changed tape. Still having the same problem. Really haven't used the camera a whole lot. Bought it last year brand new. Any suggestions before sending it in to service?
Thanx in advance for any help.
Ken
(kquon@telusplanet.net)
  • 19 Answers
SOURCE: Re-attach the power source followed by Reinsert Cassette
Hai Problem in mechanism. If the tape does not loaded completely, the message will show "Reattach the power source" Please check mechanism. Raghavendra, M/s.prathiksha Electronics
Posted on Jan 29, 2007
  • 169 Answers
SOURCE: sony dcr-trv6 shows c:31:30 and beeps
the capstan motor of your camera is stuck up....check the capstan motor is there is some debris insert at the sensor...if nothing you find check also the bushing at the upper part of the motor....
Posted on Aug 10, 2007
SOURCE: repair firewire Sony HDR-HC3
I have a HDR-HC3 and I had the same problem too... This model has ALOT of problems with transferring files and I need to pay $90 to get it repaired... Try it on a Mac, if iMovie cant pick it up it means you have a firewire problem.
Posted on Oct 10, 2007
welcomejee
  • 10594 Answers
SOURCE: External Microphone for Sony's HDR-HC3 camcoder
ECM-HZ1 Microphone is compatible as HDR-HC3 has Active Interface Shoe for this mic.
Posted on Apr 24, 2009
  • 586 Answers
SOURCE: Unable to load tape
according to the symptom you don't need reset, This problem is related to the loading tape path which is mechanically unstable, that's why problem arise, For your convenience please see the given below pic of SELF DIAGNOSTIC SYSTEM to understand better.
Your camera needs just mechanical adjustment by any expert, contact any expert nearby or from Sony for mechanical adjustment, this will solv the problem.
Thanks for using fixya.
Posted on Jul 02, 2009
HOW DO YOU IMPORT VIDEO FROM A SONY HDR-HC3 ON AN IMAC IF THE CAMERA IS NOT RECOGNIZED??
you need a third party application /codecs that recognises the sony protocol e.g. mts ext that can transcode those files either into mov,mpeg2 etc environment so that the imac recognise them
May 18, 2014 | Sony Handycam HDR-HC3 HDV Digital...
Hello, how much would it cost to fix a Sony HDR-HC3 with a C32:11 error? It's a very common problem where the tape door won't close and the camera asks to reconnect the power even if it's connected.
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair the tape mechanism and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Apr 14, 2011 | Sony Handycam HDR-HC3 HDV Digital...
We have Handycam HDR-HC3. Our old PC worked well importing videos, but eventually died, and we upgraded, but didn't check new pc didn't have Firewire. We have a spare Vista PC which has Firewire socket,...
http://forum.videohelp.com/threads/260169-Sony-HDR-HC3-driver-issue
I searched under HDR-HC3 firewire driver and got the above link.
It says the following:
Hi..
The problem was a missing MSDV.SYS file.
Thanks
D.
Actually, on the Sony site it says that no additional drivers are required to connect the camera in Windows XP, Vista, or 7.
But, the user of this camera and firewire noted that he was having trouble convincing windows of this.
Another link that talks about the firewire problem follows:
http://www.avforums.com/forums/camcorders-video-editing/480748-cant-copy-video-pc-sony-hdr-hc3.html
You can find more links by searching under 'HDR-HC3 firewire driver' or related searches to find the solution to your problem.
I hope this helps.
Jan 16, 2011 | Sony Handycam HDR-HC3 HDV Digital...
E91 Error
Manual says needs repair. Cannot find a reset button on mine. a Sony guy said to remove battery,disconnect power.....turn button to on , leave for 5 minutes....turn back to off....reinsert battery and power
May 20, 2010 | Sony Handycam HDR-HC3 HD Camcorder
The door won't close on Sony HDR-HC3
HERE'S WHAT WORKED FOR ME PER SONY TECHS:
Take?»¿ OUT the battery or disconnect the AC cord.
Turn the camera ON (tape, memory, edit settings) for 15 seconds.
Turn camera to off setting.
Plug battery or AC cord back in.
VOILA!
Worked for me and I had the stupid C32:11 error code for weeks! Door would not close. Followed the SIMPLE and SAFE instructions and IT WORKED! Just like magic. I couldn't believe it! Save your money TRY THIS!
Jan 24, 2010 | Sony Handycam HDR-HC3 HDV Digital...
I get a error code 30:23 on my HDR HC3 and it won't play or
Sony is pretty secretive about the :23 code. It can't be found anywhere. Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 120 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
Nov 12, 2009 | Sony Handycam HDR-HC3 HDV Digital...
Apr 24, 2009 | Sony Handycam HDR-HC3 HDV Digital...
Sony Handycam HDR-HC3 HDV Digital Camcorder Logo
1,528 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
