Sanyo Clicking/Ticking Sound
Hey guys I was hoping someone could help me out. I have a older Sanyo 32" and recently it has started making a tiking/clicking sound when it is on. It immediately stops when I turn it off and immediately starts when I turn it back on. The clicking sound happens about a dozen times then it pauses for a few seconds and repeats this. My audio and video both work fine. I can hardly notice it when playing a game or watching tv but when I do notice it is quite annoying.
    Top Expert:
  • Televison & ... Master
  • 29,642 Answers
That is caused by the insulation on the EHT cable or tripler leaking.
Posted on Jun 12, 2017
SOURCE:
  • 275 Answers
SOURCE: TV makes a repeated cricket sound and won't turn on.
Could also be the sound of some sparking. Before you trash the TV, or call a technician, try this. unplug the set. Open the back cover of the set, and now plug it and switch ON. Stay a little away and observe if you can see some sparking. If yes, try to localise it. Unplug the set and then wait for a few minutes and then see what is causing the sparking. Clean that area, as it could be because of some foriegn object (I have seen small rodents, lizards, etc) entering the set and getting fried. Clean it up and try the set again.
Posted on Mar 26, 2007
SOURCE: Snap, crackle sound from Sanyo TV
It sounds to me as if possibly ya Main IC Amp Chip & OR the Output Capacitors are failing... Sometimes it is a sign of a power supply on it's way out... Either way it's time for a repair shop quote. Either that or it may be the speakers crossovers... to check this, if you can, try another set of speaker... see if problem is still there. If it IS, then it IS most probably as I said above.. If NOT then it may be one or both of the "Crossover Network" in each speaker...
Posted on Sep 01, 2007
skippy101
  • 143 Answers
SOURCE: TV making clicking sounds
if you had good color yes it is worth fixing sounds like your fly back trans former may be out see if you have any blown fusesif so get back tome for more help
Posted on Nov 02, 2007
SOURCE: Constant clicking every half-second as soon as you plug it in.
I have the same problem-still troubleshooting...so far still not find the cause. DM1 power supply output voltages are operates correctly. Signal output of microprocessor up and down (no good) that turn on Q14105 and latch optical isolator U14102 to power the unit but both of ohmed out ok. it hard to troubleshoot the main board with power on.
Posted on Jan 16, 2008
  • 280 Answers
SOURCE: TV won't turn on, makes high-pitched clicking noise
Its a real good chance that the HOT (horizontal output tranistor) transistor is shorted if so the flyback trasformer may be bad also. the transformer will make a tick tick sound if it is trying to start.
Posted on Apr 10, 2009
Why is there a ticking sound when i start machine
I would try removing and reseating all the supplies, toner, fuser just to make sure something was not bumped loose while moving.
Jul 27, 2014 | Ricoh Aficio 3025 All-In-One Laser Printer
No sound from sanyo 32cefd90b
For more details type in this site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search or press Enter. It is an electronic equipments service help site.
Note the position of hyphen in between words in site name. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts.
You can locate this site name, either at the bottom part of first search page, or at the top of second page.
Detailed descriptions are there to help you.
Sometimes, clicking on advertisements by the side and bottom of each post might help you to get details about the availability of spare parts; price and more.
Jun 05, 2012 | Sanyo CE32FD90 32 LCD TV
Hey guys my refrigerator is not getting cold also i'm hearing a ticking sound coming from some where by the compressor or relay and what about having alow voltage problem could that affect it.
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Sep 09, 2011 | Refrigerators
When I shut off the motor sometimes it wont start. I just bought a new battery 2 months ago. When I turn the ignition the starter doesnt even make a clicking sound. I can jump it or let it sit a couple of...
It might be your anti-theft alarm system. When the car doesn't start, is there a ticking sound inside the car? If so, hit the unlock button a few times on your keyless entry remote, until the ticking stops, then try to start the car. Hopefully this helps.
Mar 27, 2010 | 1998 Ford Explorer
Loud Ticking sound 2004 F150
Check the Alternator / Powersteering belts .
One of them will be damaged and loose.
Hope this helps.
Jul 28, 2009 | 2004 Ford F150
Ysus board number for a sanyo 50'' plasma model dp50747
This is a Sanyo Vizon 50" plasma the model number is DP50747 .. hope this helps the website for this product is www.sanyoctv.com and the phone number is 1-800-877-5032
Mar 16, 2009 | Sanyo DP50747 50 in. Plasma TV
Nov 02, 2007 | Sanyo DS31520 31" TV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
