Question about Brother MFC 210C All-In-One InkJet Printer
When it stays on fax i can press any button and it just beeps.what do i do
  • 832 Answers
Did you unplug from power, wait a minute and plug in again?
Any changes?
Posted on Oct 28, 2007
P3015 beep
Here are some possible reasons why your printer is beeping:
1. Your printer is connected to a UPS (Uninterruptible Power Supply). When the printer goes through the printing cycle it uses a massive amount of electricity. During those few seconds of power usage, the UPS will beep indicating that it will not be able to sustain that power output for any period of time.
How to fix: Move your printer to another outlet and don't connect it to a UPS
2. You have an MFP (multi-function printer) that is attempting to fax again and again. When sending a fax, it's typical that the printer makes noises (dialing, connecting, etc). One of these noises is a fax response beep.
How to fix: Check your printers menu and turn off/down the fax volume
3. Some printers with an LCD menu and keypad make noise when keys are pressed or the printer encounters an alarm of some type. This can become annoying when typing keys for a phone number or by changing a menu setting.
How to fix: Check the menu settings for the printer and turn off/down the sound that's occuring. As an example, the HP LaserJet MFP series printers have the following sounds.
  • The alarm sound that the printer makes when it requires attention, such as when the all-in-one
    door is open.
  • The beeps that are emitted when you press the all-in-one control-panel buttons.
  • The phone line sounds for outgoing faxes.
  • The ring volume for incoming faxes.
As an example, change alarm volume by following these steps (using a 305X series printer)
1. Press Menu
2. Use the < or the > button to select System setup, and then press the green checkmark button
3. Use the < or the > button to select Volume settings, and then press green checkmark button
4. Press the green checkmark button to select Alarm volume
5. Use the < or the > button to select Off, Soft, Medium, or Loud
6. Press the green checkmark button to save your selection
Mar 20, 2014 | Office Equipment & Supplies
LHow do I increase the volume as the phone is very quiet
Hello there,
Adjusting the volume on an HP Officejet All-in-One
Follow these steps to adjust the volume of the various fax sounds.
Adjust the rings and beep volume
1.Press the Setup button P(wrench).
2.Press the arrow buttons (Left and right) to select Basic Fax Setup , and then press OK .
3.Press the arrow buttons (Left and right) to select Rings and Beep Volume , and then press OK .
4.Press the arrow buttons (Left and right) to adjust the volume, and then press OK .
Adjust the phone line and monitor volume
1.Press the Setup button (wrench).
2.Press the arrow buttons (Left and right ) to select Basic Fax Setup , and then press OK .
3.Press the arrow buttons (Left and right ) to select Phone Line, Monitor Volume , and then press OK .
4.Press the arrow buttons (Left and right ) to adjust the volume, and then press OK .
Adjust the handset volume
When you receive a call, pick up the handset of the product, and then press the arrow buttons (Left and right ) to adjust the handset volume.
Please feel free to leave a testimonial if this works and please do not forget to click 4 thumbs.
Cheers!
Mar 22, 2011 | HP J3680 Officejet All In One Printer
How do i turn up volume on hp officejet all in one
Adjust the volume
The HP All-in-One provides three levels for adjusting the Ring and Beep Volume and
the Phone Line Monitor Volume.
The ring volume is the volume of the phone rings. The beep volume is the level of
button press and error beeps. The default Ring and Beep Volume setting is Soft.
The Phone Line Monitor Volume is the volume of dial tones and fax tones. The
default Phone Line Monitor Volume is Medium.
To adjust the Ring and Beep Volume from the control panel
1. Press Setup.
2. Press 4, and then press 4 again. This selects Basic Fax Setup and then selects Ring and Beep Volume.
3. Press to select one of the options: Soft, Loud, or Off.
4. Press OK.
To adjust the Phone Line Monitor Volume from the control panel
1. Press Setup.
2. Press 4, and then press 5. This selects Basic Fax Setup and then selects Phone Line Monitor Volume.
3. Press to select one of the options: Medium, High, or Low.
4. Press OK.
Trust this is helpful. Please vote. :)
Dec 14, 2010 | HP Officejet 4355 All-In-One InkJet...
How do i fax?
First you enter phone line in to the fax machine and then feed the fax paper on the top side of the fax machine then dail the number on the dail pad after the beep press the start button your fax start work.Fax throughput and office productivity are enhanced by scanning faxes into memory while the machine is busy. You can return to work, confident that their faxes will be transmitted as soon as the line is free.
Nov 25, 2009 | Brother IntelliFax-2480C Fax
I have a Brother 2820 fax machine and it beeps when I press a button. It still receives faxes but that is it.
When it just beeps on keypress, but other functions not requiring your input (like receiving faxes), the problem most likely is a stuck button. Try pushing each button and wiggle it a little to have it "released". It may not even look pressed down, but one of them most likely is.
Jun 03, 2009 | Brother IntelliFax-2820 Laser Fax
Key pad on brother 1020e fax mc seems to be locked when you press copy for ex it just beeps 3 times
When the Brother machines beep three times while pressing any button on the front panel, this means there is a button stuck. Try pressing all buttons over and over to unstick button. This should help. Please rate my help if this works. If you need anything else, save my user name and ask me anytime. Thanks!
Jan 21, 2009 | Brother FAX-1020e Plain Paper Thermal...
Cannot fax or call out. Buttons just beep at me.
I had same problem then found one of my number buttons had got stuck down but didnt notice.
The rubber part had caought under the lip of the hole it is recessed in so i pryed it back up and
was away working again
Hope that helps
Jun 07, 2008 | Brother IntelliFax-2820 Laser Fax
Beeping
Button stuck or not in fax mode, check mode and press all buttons
menu * 2 8 6 4 then 99 is a rest code must be done very fast
Nov 30, 2007 | Brother IntelliFax-2820 Laser Fax
BEEP, BEEP,BEEP
The Start Button can become stuck on these very easily. If it is stuck, then press it down and it should jump back.
Jan 31, 2007 | Brother IntelliFax-2820 Laser Fax
Brother MFC 210C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
