Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
I have a red line right in the middle of the tv
My red wont line up left to right , picture is good in the middle of the screen but not on the sides
The R,G,B colors alignment wouldn't line.That mean ur tv have a problems known as a convergence problems,it dead.The tv convergence board require the 2 STK convergence ICS and some or all it resisrors to be replaced,to solved the convergence problems.The shop will cost $300-350 for parts and labors.
Jul 06, 2010 | Hitachi 46F500 46" Rear Projection...
I have a red line going accross my tv screen. Its
Do you have speakers next to your tv sometimes the line on your tv will be from your sound to close to your tv also the red line could mean your tv tube is going out there about 300 to replace but i ould check frist on your sound are something close to you tv that is maken the red line in the middle of your tv
Dec 09, 2009 | Sony KP-51WS510 51" Rear Projection...
Red/Orange horizontal lines
it could be that the tv convergence circuit is going bad. One shure way of finding out is to go to the tv feature menu(picture,audio etc.) and select the customer convergence setting, you should get a cross hair pattern(cross in middle of screen). that cross should be white and by aligning the red or blue colors they should move left, right, up or down
Jul 27, 2009 | Akai PT5492S 54" Rear Projection...
RCA D52W23 convergence problem
If you cannot adjust it with customer menu u need professional. May need service adjustments.
Apr 08, 2009 | RCA D52W23 52" HDTV CRT TV
Thin red line in middle of screen on nec 42 inch plasma monitor
I had the same problem -red, vertical bars along the right side of my Samsung 42" Plasma- and this is what fixed it: Removed unterminated cable.
I had hooked up an HD video camera to the set about two weeks ago. While I disconnected the camera I left the other end of the connector cable plugged into the T.V.. As I've since learned from friends who work in television, this is what's called an "unterminated cable" -meaning one end is unconnected. It can lead to problems with electrical interference and appears to have been the problem in this case; When I disconnected this cable from the T.V. the red bars went away.
So, check your cables. Make sure everything is properly connected and get rid of anything that might be picking up interference.
Dec 27, 2008 | NEC PlasmaSync 42PD3 42" Monitor
Red line runs from middle of screen to right bottom and bends in middle
look the only thing u can do is have someone put the parts in for u the parts alone is 40-$ 60.00 and maybe $ 150 in labor that is all u should have to pay. that is what i would charge a customer to repair there tv set and it can be service right there in your home.i hope this helps marty
Oct 13, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Jul 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Convergence
Have someone replace the convergence amplifiers
Feb 28, 2008 | JVC AV-48WP30 48" Rear Projection...
Red lines taking over my T,V
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 26, 2006 | Samsung HCM5525W 55" Rear Projection...
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
57 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
