I bought a brand new alternator in December 2013,couple days ago alternator wasn't charging got it tested by the auto electric who put alternator in and they say there is a electrical leakage some where. it`s under warranty the labour is free but I might have pay for another alternator, but what I want know is what electrical leakage is, could someone let me know I would really appreciate your input thank you.
SOURCE: Auto Lock Activation
Deactivating/activating autolock
There are 3 methods to enable/disable this feature. One through your
dealer, the second with a power door unlock/lock sequence and the third
with the keypad.
Before following the activation or deactivation procedures, make sure
that the anti-theft system is not armed, ignition is off, and all vehicle
doors, liftgate and liftgate window are closed.
Controls and features
Power door unlock/lock
procedure
You must complete steps 1-5 within
30 seconds or the procedure will
have to be repeated. If the
procedure needs to be repeated,
you must wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control. The horn will
chirp once if autolock was deactivated or twice (one short and one long
chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the
procedure is complete.
Keyless entry key pad procedure
1. Enter 5 digit entry code
2. Press and hold 7/8 control
3. Press and release 3/4 control
4. Release 7/8 control.
The user should receive a horn
chirp to indicate the system has
been disabled or a chirp followed by
a honk to indicate the system has
been enabled.
Smart unlock
This feature prevents the driver’s door from locking while the key is in
the ignition. This feature will unlock only the driver’s door if the key is in
the ignition cylinder, the driver’s door is ajar and all doors are locked
using the interior trim switch. If these conditions are met, the entire
vehicle will lock and the driver’s door will unlock within 1 second.
127
SOURCE: 02 Ford Explorer XLT 4x4 High light flashes and
I had same problem on my 2002 explorer. Its either the computer module, or the electric solenoid on the transfer case. In my case it was both. The computer module I had done twice in 14 months.
SOURCE: 2002 ford explorer xlt 4x4... Vehicle won't start
My 2002 Ford Explorer have the same problem
