The laptop does not trun on even the plug in light keep coming.
i keep it switched on for a while. then i turn it on and off many times.
finally it starts normally and works without any problem.
1. No LED flash, no display at all of any kind like boot info or bios loading etc. 2. Power light will be on. hard disk light will be on as usual and keep spining. 3. no beeping sounds. 4. no video indication 5. i have even changed the battery but this prblm persists _______________________________________ after i keep it plugged on for a while, then i turn on and off many times and finally it turns on.1. No LED flash, no display at all of any kind like boot info or bios loading etc.
If it is a drive problem, then atleast the startup display should come. the laptop does not show loading of boot setup. if drive is failed then it should fail at the time of loading operating system or recognition of drives.If it is a drive problem, then atleast the startup display should come. the laptop does not show loading of boot setup. if drive is failed then it should fail at the time of loading operating system or recognition of drives.
i took your advise and used a different hard drive and it started without any problem.i took your advise and used a different hard drive and it started without any problem.
When you first try to turn the system on, are there any power indications? LEDs flash, Drives spin up? Beeping sounds? Any video indication at all?When you first try to turn the system on, are there any power indications? LEDs flash, Drives spin up? Beeping sounds? Any video indication at all?
You can't post conmments that contain an email address.
The MOST likely senario that I've seen with similiar indications involved a hard drive that is slow to spin up to speed. Hence why multiple attempts, with the drive not coasting to a full stop between attempts, the drive finially makes it to operating speed and the system boots.
Try with the AC adaptor connected and plugged in. It may be a faulty battery or something more serious. Make sure the power light comes on when the charger is plugged in and switched on. In the evenit is still the same let me know.
the batteries eventually wear out and quit taking a charge. You can run the system without a battery with no ill effects. replacements are about $100 for a new battery
Below is a link that gives you an illustrated view of the disassembly of your laptop. It be that the wire from the video cable has popped out of the inverter. When you remove the bezel from the lcd panel, check the plug connections on the inverter before changing the inverter out.
if you do not have the bios password you have to open it ..and clear bios by short the pins if you find them...or remove the bios battery for 10 seconds..and will be on factory optimal defolts
