Ariens 926LE Model #926007 Serial #001931 Pull cord broke...rewind housing is attached by rivets. Is there any way to replace cord without drilling rivets?
SOURCE: I have a cub cadet lawn mower broken pull cord
just rewind the spring starting with the outer end and fill it back into unit. I always have the rope extended and rewind it back in and reinstall
SOURCE: I need to replace the pull starter cord on my self
There will be bolts that hold the housing that have the rivet in. Remove the bolts and remove that housing. Make sure you have the right amount of cord and the proper size rope. You WILL NOT have to remove the rivets. Remove any rope that is still in the recoil pulley. Now you will have to have a small screwdriver or some thing that will be used to hold the pulley from unwinding. Now you have to turn the pulley counter clock wise. You want good tension. Put the screwdriver through the fins in the pulley so it won't unwind. Make sure you line up the hole in the pulley with the hole in the shroud. Put rope through and tie a knot. Tie the handle on and then remove the screwdriver and slowly let the rope back in. Try pulling a few times to make sure you have enough tension. When enough reassemble the shrouds and give it a pull.
Good luck
roundo4
Testimonial: "Thank you. I'll give it a try."
SOURCE: Craftsman 917-377150, the pull cord
Remove the recoil assembly from the mower, there are 3 machine screws.
Remove the old rope and get matching cord, make sure you get the correct diameter, usually 3/16 or 1/4 inch, and type, I believe it should be nylon braided. Do not cut the new cord.
Use a match to light the end of the cord and once it ignites, use an old rag to pull and form the end into a point.
Notice which way the pulley in the starter assembly rotates and hand spin it in that direction until it is fairly tight. Once it is tight, rotate it into a position such that you can push the pointed end of the cord from the outside into the hole in the housing of the starter and directly into the hole on the inner pulley. Tie a tight knot in the end of the rope inside the pulley.
Remove the clamp and let the rope get rewound on the pulley. Cut the cord, point this end and run it into the handle and knot it.
