Computers & Internet Logo
s
sazzadshipu1 Posted on Feb 19, 2014
E0001 for fifa14
I am installed fifa14 but here a problem E0001. I am trying to solve this problem but I can't do it.
mohish shershiya
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Mar 03, 2014
mohish shershiya
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
3824
Points
31
Just go on this website and watch you http://www.youtube.com/watch?v=VrtzvXtYcCE
E0001 fifa 12
This means your GPU is to low of a model to run such standards needed, the main way is upgrading your GPU. Follow this easy steps and guidance for upgrading your GPU; http://www.pcworld.com/article/225823/how_to_upgrade_your_graphics_card.html
3helpful
2answers
I cant start my fifa 2011, shows me E001
Fifa 11 Demo PC E0001 Error Issue
Fifa 11 E0001 error happened to a PC with this or a similar Specs: Pentium dual core, integrated Intel graphic card, 1GB of RAM, 128 of vid RAM, 2.0 pixel shaders.
Fifa 11 Demo PC E0001 Error Issue Fix:
1. Fifa 11 requires a shader model 3 or better card. That is error E0001 will be fixed and you can play this game again.
So if you get an error message as E0001 while playing Fifa 11 on Windows 7 or other systems, you should first set to the shader model 3 of your card.
2. This E0001 error issue may also be related to the graphic card that you are using. Check the drivers you are using for the video card. Update and reinstall it if necessary.
3. Get the latest driver pack for the same and then process out for the implementation. You can download the current new AMD catalyst 10.9 graphics card driver here. Or NVIDIA ForceWare 260.63 driver if you are using a Nvidia card.
4. Change the resolution to have a try. Some users get the E0001 error fixed for Fifa 11 by trying the 1280x1024 resolution on his computer.
Hope this solution was helpful? Please comment for more information and thank you for using fixya
3helpful
My fifa 11 no working e001 problem
1helpful
I installed FIFA 11 on my PC and when I run it it comes up with a box say 'E001'.
4helpful
2answers
When i run fifa 11 after opening fifa config it shows "e0001 error" please help me !
E0001 ERROR -> Fifa 11 requires a "Shader Mode 3" or better card. That is error E0001 will be fixed and you can play this game again
You can try updating your graphic cards to the latest drivers from Manufacture Site, update your DirectX to the lastest too. If the problems is not solved, then you have to get a better card in order to play the game.
FYI
Chipsets used in models:-
NVIDIA GeForce 7300, 8100, 8200, 8300 und 9300,
ATI Radeon HD3200, HD4350, etc.. and
Intel/S3 do not satisfy the hardware requirements.
Hope it helps
4helpful
2answers
When i start my fifa 11 then it can't start its writting E0001,what shoul i do?
Lol just change your resolution and then change back....worked for me
6helpful
I INSTALLED FIFA 11....BUT WHEN ISTART THE GAME IT SHOWS E0001 ERROR..........PLS HELP ME........
FYI
Hope it helps.
2helpful
3answers
I installed Fifa 11 When i start it, a dialog box appears stating "E0001" whats the probem and how to solve it?
This is due to your graphic card not supporting "Layer 3 mode or better". You need a better graphic say with "layer 4 mode" support to play the game.
FYI
ATI Radeon HD3200, HD4350 and
Hope it helps.
6helpful
What does E0001 mean when installing FIFA 11?
Error Message E0001 = This game requires a shader model 3 (or better) card. Your Card doesn't support pixel shader v3.0 probably.. this is usually the case with unsupported graphics cards.. bad luck dude.
Grand Canyon Tech
Grand Canyon Tech
