The batt maybe bad-not holdin 12.6v-or altrnator worn -not chargn--chec all connections for corrosion---a coil ignition needs that voltage and not a point lower or spark is not strong enuf------u can replace the batt w a capacitor called and eliminator-sold by accel--if u have a kikstarter-its nice cause no mor maintence-wil start like a lawnmower
SOURCE: suzuki gn125 wont start. checked carb, cdi, coil.
Check the valve adjustment. If a valve is standing open just a little, the compression will be too low to start the engine. Check fuel delivery by dribbling a little gasoline into the carb and try starting the bike. If it starts and runs for a second or two, you're not getting fuel into the cylinders. Check you carb again.
SOURCE: kawasaki 300 bayou won't rev up.
No guarantees but try this. Pull the slide from the throat of the carb. Now move the clip on the jet needle down one notch. This will richen the low end mix. Two notches may be needed but do one notch at the start.
SOURCE: Yamaha timberwolf wont start unless push started
You have a loose connection to the ignition system . When cranking make sure it is in neutral. and kill switch is in run position. The only thing dropping would sensibly affect is the fuel system or jarring a switch., but with the suspension you have there really is no jarring. So, I would ck the wiring. something is loose.
