If "English" did not display, repeat steps 1 thru 2.
Still having Problem Then follow Us For Brother Printer Support
SOURCE: Change Language on Brother MFC-215C
PLEASE, can anyone be sure of the eeprom code for GB before I start the procedure, I tried to contact the hotline but I'm not sure of their phone number either.
Thanks for ur help
SOURCE: change LCD language to English on Brother MFC-3240C
Gud Day!
Power on your printer. Press the menu of your printer then sect the arrow down or up to select the language menu. press ok if u have seen language then go to option select from german to english.
Please rate the solution after you have tried it so that I can assess you more on this problem.
Jonags
SOURCE: changing language from french to english
http://safemanuals.com/zearchres_134.php this site allows you to get the manual for the machine this should help,
SOURCE: how can I change the language?
Go to the Brothers website and download the latest software for your machine. In the process it will ask you what language you prefer, choose English and then your menus from that point on should be in English.
SOURCE: need manual for brother fax 510
http://www.brother-usa.com/Manuals/Default.aspx
select your model and download .
