Question about RCA F36668 36" TV
RCA MODEL# F36668 TV, 36" OR 37"
T.V. WAS WORKING FINE AND THEN JUST ONEDAY IT WOULDN'T TURN ON ANYMORE, IT'S LIKE IT HAS NO POWER. I HAVE UNPLUGGED TV AND WAITED OVERNITE PLUGGED IT BCK . IN AND IT STILL DOES NOT TURN ON!  WE HAVE ONLY HAD THIS TV 6YRS GIVE OR TAKE A YEAR.. IS THIS SOMETHING THAT SOUNDS  AS IF IT COULD BE FIXED RELATIVLY CHEAP, OR WOULD IT BE BEST TO JUST GO OUT AND BY A NEW ONE?
MICHELE.COBERLY@SBCGLOBAL.NET
  • 1 more comment
  • mishele coberly
    mishele coberly Oct 29, 2007
    I have taken the back off and I believe I have located the fuse..if it's the 5amp 120v one, the yes I have found it...I am now off to buy a new fuse.. Hopefully this fixes it....I will let you know !
    Thanks for your help. We have thrown 2 or 3 TVs away in the past that have done this same thing, we just assumed it would be cheaper to buy a new one, however all the other TVs were smaller tv's  and not as expensive as this one.
  • mishele coberly
    Ok, i replaced the fuse  , and yes the fuse was blown, However....as soon as I plugged the tv in after replacing the fuse, it blew again.....so the blonde that I am, I replaced the fuse yet again........and yet again when I plugged the tv in , the fuse blew again.   So, now my question is..what could be causing the fuse to blow everytime its replaced and plugged in; and will this be worth fixing?
    You could hear the fuse blow and see a spark just as soon as the TV was plugged in.  the first time I just heard it because I had already put the cover back on , but the second time I plugged it in without putting the cover on, and there was definatly a spark.
    thanks again for all of your help...
  • mishele coberly
    mishele coberly Oct 30, 2007
    Ok, well thanks for all your help! it was worth a try......
  • 70 Answers
If you feel comfortable taking the cover off the back, check the fuse that should be soldered into the board, near the power cable/etc.  If you do not feel comfortable doing that, then you should have a repair shop take a look at it.  It might be a cheaper fix than you think.
Posted on Oct 28, 2007
  • Justin Patterson
    Justin Patterson Oct 30, 2007
    well, at this point, it could be multiple things.  If you look at the boards, and wires, make sure that there isn't anything shorting out, or burned, etc.
    As far as if it's worth fixing, that depends on whether or not you wanted a new tv, just kidding....
  • lesley l cleaver Sep 16, 2014
    Justin your funny lol ok i'll pull bak off as i have no problem looking as i'm into trying to fix two diffrent projection tv's too lol
Can't find a service manual for an RCA f36668
Send your email address to me by Fixya, and get back a copy of it by return mail.
Dec 27, 2012 | RCA F36668 36" TV
Rolling lines on screen
Sounds like the power supply has a bad capacitor. This problem can inject excessive 60 hz from the AC line into the vertical stabilizing picture system. The hum also my come from the same reason, bad or leaking filter capacitors. Cheaper just to buy a new TV or borrow another TV and connected to your system to see if the problem still occurs.
Mar 16, 2009 | RCA F36668 36" TV
NO COLOR IN MY RCA F36668 TV
Could be a bad TV or it could be loose TV connections feeding to the back of the TV. Any poor or loose connections in the cable leads causes a loss of signal strength to the TV.
Old cables and connection supplying TV Cable to the house or apartment can cause this problem also.
Dec 05, 2008 | RCA F36668 36" TV
RCA tv with guide plus comes on and off randomly
these tv's are bad for caps in power supply, fluctuations freaking your micro.
Aug 19, 2008 | RCA F36668 36" TV
TV turns on & off by itself. Channels also change by themselves.
Make sure your remote is totally away from the set.
Make sure the buttons on the set are not sticky
If both of those are ok, it's your E-Prom in the set. RCA's are notorious for this, not a major repair, maybe $75-100. The 8 leg e-rom is only about $6.00
Apr 11, 2008 | RCA F36668 36" TV
Television malfunction
If you know how to solder - solder around Flyback transfomer,if not you need to order a deflection power supply board.this is where your problem is.ThankYou for using FixYa. Have a Nice Day.
Feb 10, 2008 | RCA HD52W59 HDTV Projection Television
Can't get some channels anymore
You need to turn antenna off and put to cable in menu
Dec 27, 2007 | RCA F36668 36" TV
TV won't come on!
your system control section has failed due to sudden power failure. 1please check power to system cotrol. 2check tunning &aft ckt in system. 3check memory ic & its section 4check system ic & its section regards
Sep 12, 2007 | RCA F32650 32" TV
No Volume Unless
you might want to take it in to a repair station. The buttons on the front might need replacing.
Jan 25, 2007 | RCA F36668 36" TV
RCA F36668 36" TV Logo
174 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
