Question about Sony Ericsson V600i Cellular Phone
V600i will not turn on ...
My v600i will not turn on but a white screen comes  flashing at intervals when a button is pressed  . It is only a year old and has been great up to this point . Help please ..... or is it stuffed !
  • 3 more comments
  • kkkvvv Jan 03, 2008
    sony ericsson v600i doesn;t turn on when i push the power buton.when i charge it after a wile the screen is light but nothing more
  • Anonymous Mar 09, 2008
    my v600i will not turn on but a white screen comes flashing at intervals when a button is pressed . It is only a year old and has been great up to this point . Help please ..... or is it stuffed !
  • mhebrawi Mar 09, 2008
  • Anonymous May 02, 2008
    sony ericsson v600i doesn't turn on when i push the power buton. As i charge it the light will be on but no response whatsoever when i push the start button. Please i don't want to loose this phone. (if possible give multiple solutions-surely one of them must work)
    Possible cause- Taking out the battery very often to interchange CellC and Vodacom SIM cards,especially on weekends
  • o1bryan Jun 26, 2008
    i just have the same prob can some one know the master reset code for this phone.
I had same issue, to resolve i plugged in charger then whilst on charge removed then replaced battery.
It now operates as should.
Hope it sorts your too.
Posted on Jan 28, 2008
  • 70 Answers
Sounds like you may have a battery issue, try a new battery first, after that, you might as well get a new phone, since repairs are going to cost more than the phone does.
Posted on Oct 28, 2007
How to reset a service interval indicator on a 2003 mini one
Resetting Oil Service Light on your 2002 - 2006 Cooper and Cooper S Hatchbacks, and 2005 - 2008 Cooper and Cooper S Convertibles:
1) Press and hold the trip button
2) Insert key and turn to position 1
3) Watch for RESET to appear
4) Release the button, then press & hold it again
5) Wait for the RESET to flash
6) Release the button, and then press & release (once only)
7) Service interval should then be reset to next interval
If that didn't work, try this:
1. Push the Trip Button
2. Turn ignition key to position 1 and 51A will appear to left of mileage
3. Release trip button
4. Wait 3 seconds
5. Push trip button
6. Wait (5-8 seconds) for RST to appear in left corner
7. Release trip button
8. Push trip button
9. 15000 will appear as new service interval
10. Release trip button
Or this:
1. Press and hold the trip odometer button.
2. Insert car key and turn it to the fi rst position (not the second position).
3. You will see 51A come up in the trip odometer area.
4. Release, then press and hold again.
5. Watch for the word "RST" to appear on the Odometer indicator.
6. Release, then press and hold again.
7. Wait for the "RST" message to fl ash.
8. Release, and then press & release (once only).
Jul 01, 2014 | 2004 Mini One
520230. 31520193. 7Polaris 550 Xp eps 2009About 20 hours on unitStored indoorsI understand one code is Idle air and the other is power steering is disabled or not functioning. First I would try and...
Diagnostic Mode
The diagnostic mode is for informational purposes only. Please return your ATV to your dealer for all major repairs.
As long as the gauge is in the diagnostic mode, the wrench icon will remain lit.
To leave the diagnostic mode, turn the key switch off and on.
NOTE: Any movement of the tires will also take the machine out ofthe diagnostic mode.
To enter the diagnostics mode:
1. Turn the key switch off and wait 10 seconds.
2. Set the park brake and shift the transmission to neutral.
3. Hold the mode/reverse override button and turn the key switch on.
4. Release the switch as soon as the display is activated.
The initial screen display refers to the software version installed in
your ATV. This information is displayed briefly.
Use the mode/reverse override button to toggle through the diagnostic
Screen 1: Battery voltage
Screen 2: Tachometer
Screen 3: AWD diagnostic
This gauge indicates whether or not current is flowing through the
AWD coil (only on models with switchable AWD).
Screen 4: Gear circuit diagnostic
This screen displays the resistance value (in ohms) being read at thegear switch input of the gauge.
Instrument Cluster
Rider Information Center
Diagnostic Mode
Screen 5: Programmable service interval
The purpose of the programmable service interval is to provide the consumer and dealer with a convenient reminder for routine maintenance. When your vehicle leaves the factory, this feature is set at 50 hours. You must enable the programmable service interval before it
can be used.
Once the service interval mode is set with the hours when service is due, the hours of actual engine operation are subtracted from the set
hours until 0 is reached. When the counter reaches 0, the wrench icon will flash quickly for 5 seconds each time the vehicle is started as a reminder that the periodic maintenance is due.
To set the hours, press and hold the mode/override button until the wrench icon flashes. When it begins to flash, release the button. The setting will increase by one hour each time the button is pressed.
Pressing and holding the button will allow the numbers to escalate much faster. When the desired time increment is displayed, release the button and wait for the wrench to stop flashing. When the wrench stops blinking, your service hours are set.
NOTE: If you scroll past the intended number, hold the button down until the count turns over to 0. You can then reset the number.
If the service interval is enabled on your ATV and you wish to turn it off, toggle to the service interval mode. Press and hold the mode button for approximately 7 seconds until the word OFF appears in the
Rider Information Center.
Jun 28, 2013 | Polaris 2009 Sportsman 550 EFI XP With EPS
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
I changed oil how do i make the maintenance grid recognize it
You must manually reset the system
BMW Oil Service reset for 2001 ~ current model year
- Ignition OFF (POS 0)
- Press and Hold the trip odometer button while turning key to position 1 (ACCESSORY)
- Keep the button depressed (about 5 secs.) until you see "Oil Service" or "Inspection" with "Reset" or "Re" in the display
- *Note: On vehicles with "High" cluster, you will also see the amount of fuel (in litres) remaining until next service
- Press the button again and hold for approx. 5 secs. until "Reset" or "Re" flashes
- While the display is flashing, briefly press the button again to reset the Service Interval. After the display has shown the new interval you should see "END SIA" for about 2 secs.
Note that if the "Reset" or "Re" does not flash, then you have not met the minimum consumption level and cannot reset
Sep 06, 2012 | 2005 BMW X5
The display on my V600i is blinking white...the on/off button doesn't work...Help!
dear sir
i have sony v600i cell phone few days ago display bliking & on /off switch not working now i want to know what hardwear can flash this phone. Please help me Sir,
Aug 29, 2010 | Sony Ericsson K600i Cellular Phone
Maintenance reset button, how to turn it off?
NOTE: If the service interval indicator flashes it may be caused by one of the service interval indicator parameters not being programmed. This can only be done with suitable diagnostic equipment. Always check for any stored trouble codes as this may affect the resetting of the service interval indicator.
Turn ignition key to position I. Press and hold reset button [A] 20573 for trip meter. Turn ignition key to position II. Keep button [A] depressed until service interval indicator flashes (approximately 10 seconds). Release reset button [A] within 5 seconds. There will be an audible signal when reset complete. If reset button is not released within 5 seconds, the service interval indicator will not be reset but will stop flashing.
Aug 25, 2010 | 2000 Volvo S80
I-Inc iF191D wont stay on
You have a blown power supply. If it is less than a year old its under warranty, send it in for repair. If it is out of warranty our site can show you how repair the internal power supply. Our site is : click on the link at the bottom for monitor repair.
I hope this helps, if so please rate our solution.
Corporate Computer
Sep 24, 2009 | Hannstar I-Inc iF191DPB 19" LCD Monitor
How do you reset change oil light on mitsubishi outlander
Turn the key off.
Press the "Info" button on the left of the dash cluster until your maintenance miles/months screen is displayed.
Press and hold the "info" button until the maintenance screen begins flashing.
Release the "info" button and then push and hold it it for one second.
Your Maintenance intervals should reset to +6 months and +7500 miles since the last interval amount.
Note that if you have not reset it for more than one interval, you may need to do it more than once. If you have not done it for many intervals, you may need to have it reset with the scantool at a dealer, as I have run into a handful of vehicles that the oil change reminder locked up after 3-4 "intervals" were skipped/not reset.
Sep 11, 2009 | 2007 Mitsubishi Outlander XLS
Won't turn on, just a white screen flashes
My old phone did this, i had to get a new one, :/
Apr 17, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Olympus fe-210 screen probloms
try the power reset by pressing the power button for about 10 seconds with batteries out... if this does not work then repair
Aug 30, 2008 | Olympus FE-210 Digital Camera
Open Questions:
See all Sony Ericsson V600i Cellular Phone Questions
Sony Ericsson V600i Cellular Phone Logo
212 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
