Question about Canon PowerShot SD600 Digital Camera
Battery door broken does not luck - Canon PowerShot SD600 Digital Camera
The battery cover was broken of my camera
Unless it can be glued back together you are in trouble. The company may sell parts but doubt it. I have not had much luck tryong to get parts like that. Battery doors break often an they just say no replacement. Contact Pentax about it not a camera store unless you plan on them installing the door. Good luck on this one.
Oct 30, 2014 | Pentax Optio E10 Digital Camera
How can i open my craftsman 315 garage door opener with a broken remote?
you might have a power failure. can you still use the wall unit?
Mar 26, 2013 | Craftsman Building Materials
No power window function
Try fuse's first. If all is good the most common problem is the rubber boot between the drivers door and the door post which has the wires running through it, cut it open with a razor blade and take it out. You will find broken wires there. Disconnect the battery , solder the broken wires together matching the proper colours together. tape them all up one by one and then all together. Reconnect battery and try windows now. Good luck hope this helps.
Aug 31, 2010 | 1996 Buick Century
Battery door latch broken
Unfortunately HP will not sell you a camera battery door. If you can find another camera that is broken with a good battery door you may have a chance.
To repair/transfer the new battery door, you will have to use a small jewerly store screw driver that you can buy at the dollar store and use it to push the door hinge bar to one side of the camera.
Then, pull the door hinge out but be careful not to lose the tiny spring that is installed in between the hinges. ( Make sure that you know and understand how to put it back the same way.) You can then pull the battery door from the camera.
Do the same thing to good camera. Practice on the broken camera first. The second time it should go easier for you. When you install the new battery door, push the hinge bar in all the way to one side of the camera. Hold the door to give you the proper alignment and then use the small screw driver to pry the hindge bar from the one side to make sure that it is equally in each of the black hinge connectors.
This worked for me. I was fortunate enough to find someone who had a broken HP MZ67 digital camera that had a "good" battery door. It took me about 30 minutes to complete the job. I hope this will help you. You can email me if you need more advice. I am a computer tech.
Steve (SCBENDER@AOL.COM).
Nov 15, 2009 | HP Photosmart MZ67 Digital Camera
Battery door latch broke off body of Canan A590
The same thing happened to me this week. I called Canon Canada directly and asked to order the part (The battery compartment door). They gave me a phone number to call and I was able to order the replacement door for about $8.00 + $10-$12 shipping. Hope this helps!
Jul 10, 2009 | Canon PowerShot A590 IS Digital Camera
Broken memory card/battery door
I found this site with some replacement parts and battery doors looks the same. I dont know if is original. I also have the same problem. If any of you have found the part in a different web site.. just let me know please.
Jul 31, 2008 | Cameras
Canon digital camera
Same problem here with broken battery cover door! Called Polaroid and NO they do not have these parts to replace....if the camera was under warranty Polaroid would have replaced the entire camera.....soooooo when you find out any info as to where to get the battery door list the info! Thanks! & good luck too!
May 22, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-Shot Battery Compartment Door Broken
I'm having the same problem with my DSC-W1 camera. I dropped my camera and the battery door latches broke.
I found a replacement door on Ebay for $9.95
I followed the instructions in the description and easily removed the broken door from my camera. Now i'm just waiting on the new door to arrive so I could slide the new door in.
I hope this was helpful.
Here's the seller I bought the door from. Hopefully the seller has more doors. =) :
http://cgi.ebay.com/Sony-DSC-W1-battery-door-silver-battery-cover-lid_W0QQitemZ110250995036QQihZ001QQcategoryZ107892QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
In addtion, I found the last two posts on this forum very helpful:
http://www.digitalcamera-hq.com/digital-cameras/sony-cybershot-dscw1_question.html?qid=2382
Good Luck! =)
Mar 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
Broken Battery Door
I have the same hp 850, No way to fix it, So to hold the Battery Door Down, I Drill'ed a small hole through the top. & through the case
where, the camera latch Broke, & do it Real Slow..... Put a Sheetmetal Screw in the hole i drilled & it Work's Find. Just do it SLOW<<<<<<<< Good Luck & it's up to You What size to use
So Think it Over before you Try it....Slow slow slow, & the right size Drillbit,screw, & turn it in Slow.. P.S. It was do that! or $500
Down the Drain, Good Luck, The Wizard
Dec 15, 2007 | HP Photosmart 850 Digital Camera
Seeking Canon Powershot A520 Battery Door.
You can probably pick up a "broken" A520 on Ebay for $20 or less and use the parts from it. There are always some listed, but there are a few bidders who are in business picking up these cameras and "fixing" them to sell again. Good luck.
Steve
Oct 14, 2007 | Canon PowerShot A520 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
