Question about Clarion APA2001 Car Audio Amplifier
2 channel clarion car amp
I gota 2 channel clarion car  amp...its gaining switch is broken ,can u tell me from wheere i can it fix get.
  • 70 Answers
Re: 2 channel clarion car amp
you can search for the closest service provider at this website.
Posted on Oct 28, 2007
0 characters
3 Points
Car amplifier just shut off and goes on and off when it wants
Driving the amplifier too hard causes it to go into protect mode to prevent damage. The amp periodically recovers and operates normally until the next overdrive peak hits it.
Apr 21, 2014 | Clarion Car Amplifiers
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
Have 600w amp 2 10's and they aint even bumpin, DO I NEED TO BRIDGE IT
No, that'll use two channels to power one sub. First, is the gain turned up? There's a knob on the amp to turn it up. If the gain is already up, and if the amp is two-ohm stable, then wire the subs in parallel. I'm assuming the subs are each hooked up to their own individual channel. Swap the two negative wires at the amp, so sub 1 is hooked up to channel 1 positive and channel 2 negative, and vice versa for the other sub. That'll dramatically increase the output. Again, make sure the amp documentation says it is 2-ohm stable, or you'll damage your system.
Dec 24, 2009 | Kenwood KAC-729S Car Audio Amplifier
I have a boat with Clarion CM1635 speakers, how do I size the amp for my speakers
Hello cgregerson,
If you are running just the front channels to 2 CM1635's, you will need a 2-channel marine certified amp with approximately 50 watts RMS output per channel.
The MB Quart NAU-260 here would be a good inexpensive choice.
For a little more power and quality, I'd recommend the JL Audio M2150.
To run both front and rear channels, you need a 4-channel amp with 50 watts RMS per channel.
The Kicker MX350.4 marine certified amp would be a good choice.
Hope this helps.
Oct 14, 2009 | Cyclone Car Amplifiers
Clarion apa4320 amp power light pulses
There is not enough power coming from you radio to power the amp. You might want to look in to a capacitor. What this will do is it will pull in the power and maintain a steady output for your amp to operate
Mar 18, 2009 | Clarion APA4320 Car Audio Amplifier
Clarion APA5240 5 channel Amp
try this it has worked for me in the past,..Contact Clarion by e-mail .Tell them your a student and learning electronics and in need of installation ,owners manual..ask if they can help and mail you info you need.Or try this link ..Its for a APA5241 could be very similar..
Dec 14, 2007 | Car Amplifiers
I need help
Make sure your ignition signal wire didn't come loose somewhere. Was the Amp exposed to extreme heat?
Jun 19, 2007 | Clarion APX2120 2-Channel Amp - 120W 180W...
My amp powers on but no sound output..
My Clarion is doing the exact same thing...and im starting to lean towards a failure in the powersupply of the just cant produce the sound.
Aug 20, 2006 | Kenwood KAC-728S Car Audio Amplifier
Clarion APA2001 Car Audio Amplifier Logo
146 people viewed this question
Top Clarion Car Amplifiers Experts
Robert Rankin
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you a Clarion Car Amplifier Expert? Answer questions, earn points and help others
