Question about Philips DVP642 DVD Player
DVP642/ 37 DVD player says "NO DISK" with any disk.
I've seen two postings of people with this same problem. I've had the DVD player for a little less that two years and all the sudden it reads "NO DISK" to any DVD or CD that I play. Cleaning the lens didn't help. Once in a while it will play a disk, but it will soon freeze, then go and repeat til it finally stops. How can this be fixed? I really don't want to have to send it in somewhere. HELP!
  • 22 Answers
Re: DVP642/ 37 DVD player says "NO DISK" with any disk.
Usually if there is a NO DISC error, and the lens is verified clean, there is either dust in the laser assembly (use a can of compressed air to clean it out) or a loose laser assembly cable. Also check to make sure the lens can bob (wiggle around), and that it can slide back and forth.
The emergency eject is underneath, its a small slot. Insert a toothpick at one end and slide to the other end to open the tray.
Posted on Aug 30, 2008
  • 12 Answers
I've have the same problem. I took the cover off clean the lens and thought that fixed it, but it happened again a week later. This time I slowly slid the laser toward the rear of the case, then tried putting the disc in again. The laser moves across the disk and it starts spinning (I noticed before that the disk never spins and displays no disk). So cleaning the lens only helped because I moved the laser in the process causing it to start moving. I cleaned the bar and the rail that the laser slides on with WD40 (because that's all I had handy). We'll see if that does the trick, if not I'll Velcro the cover on for easy access until I can afford a 1080 up-convert player (in this economy I'm not spending unnecessary money).
Posted on Nov 15, 2009
0 characters
3 Points
Dvd draw wont open without the remote
VCR combo?? I had to check the date on this post to see if it was from 1990. Do you still view VCR recordings? If not, then trash it and get a DVD player. I've seen them for less than $20 new.
Jun 21, 2012 | LG V181 DVD Player/VCR
Dvd player skips and stops
You may need to buy a lasor cleaning disk. It's a disk that has a little brush on it and it quite literally dusts the lasor inside the dvd player. (higher chance of it being this if it's an older player, or you've had it a few years.) Where to buy:
Jan 16, 2012 | Samsung DVD-P171 Player
Why won't the DVD-RW disks FORMAT? I've seen others with the same problem with formatting multiple types of disks... Please help.
If you are using a Sylvania DV220SL8 DVD Player \ VCR combo (which this question is posted under the heading of) there is a very simple reason why you can't format DVD-RW disks. DVD Players can't do that. You need a DVD Recorder to format DVD's.
This applies to all comments under this heading as well. You can not record if the unit you're using does not have that capability. And this unit does not have it. You can record with the VHS VCR, but the DVD Player is just that... A Player. It's not a Recorder.
Sep 09, 2011 | Sylvania DV220SL8 DVD Player/VCR
Hello. My DVD player will not play past the first few seconds of DVD. I've tried with 3 different disk and the same thing happens. I've cleaned all disk and still haven't been successful....
What I can think of the Lens inside your player may have dust etc on it.
If you have a CD/DVD Lens clearer disk try that, Then see if you can get it working better.
Jul 28, 2011 | DVD & Blu-Ray Players
Disk rotating and a message "invalid disk"
you can try manually cleaning the laser lens ( gently wipe , do not press down hard , it is suspended by fine wires ) using a q-tip and a drop of that cleaning solution you got with the laser lens disc. ( fluff another q-tip a little ) then dry wipe it with another q-tip and try a disc.
you can look at the laser lens and see if you see the laser come on also to determine if that is working ( do not look directly into the laser ! )
if the laser works but it still does not read discs after cleaning it manually , then there is a problem with the focus coil on the laser or the signal board is bad
Jan 10, 2009 | Coby DVD-211
May samsung dvd player does not play any disk i always seen
Try with other disk . May be that particular disk is damaged .
If your problem still exists you need to clean the lens with lens cleaner kit .
Hope this helps.
Dec 03, 2008 | Akai DVDP5851 DVD Player
"NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
Sep 22, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
Samsung vcr dvd jumps
thats either a faulty disk or dust in the player. Get a cleaner for the cd player, such as a cleaning disk
Jun 11, 2008 | Samsung DVD-VR330 VCR and DVD Recorder
DVP-NS50P will not load DVD
the lense could be only dirty, try cleaning it first. i suggest do a manual cleaning if you can. open the top cover of the unit, remove the disk retainer and you will find the lense somewhere in the middle. use a cotton bud, use a little of alcohol, dampen a little only and wipe the lense in circular motion. then use new dry bud to dry it.
May 04, 2008 | Sony DVP-NS50P DVD Player
Philips DVP642 DVD Player Logo
3,210 people viewed this question
Top Philips DVD & Blu-Ray Players Experts
Level 1 Expert
rugby prop
Are you a Philips DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
