Home | Kirby | Ultimate G Bagged Upright Vacuum | G-5 Kirby sel...
Kirby Ultimate G Bagged Upright Vacuum
Problem for Kirby Ultimate G Bagged Upright Vacuum
G-5 Kirby self-propel works intermitently. The
By letherberdoi on Jun 10, 2009
G-5 Kirby self-propel works intermitently. The handle must be jiggled until it engages forward. The same for reverse. Once underway it will continue indefinitely until the need to change direction. Jiggle go forward,jiggle go in reverse. It seems as though it helps to push the handle at an angle to the left depressing the switch on the left side at the base of the vacuum head.
Solution #1
posted on Jul 18, 2009
Not Rated)
robautomatic
Rank: Apprentice
Rating: 0%, 0 votes
sounds like a loose wire, the wire is connected to the handle, you may be able to fix this yourself but be careful you can void the warranty by doing it your self. (most people make the problem worse) remember your kirby has a lifetime warranty (limited) the first 3 years anything and everything, after that for 175 dollars you can send it in and get it rebuilt to the newest model no matter how old it is as long as the person is still alive that signed the warranty card.
hope that helped.
rob
Was this helpful?
Yes
No
Popular Solutions for Kirby Ultimate G Bagged
Questions and Unsolved Problems for Kirby Ultimate G Bagged
Do you recommend Kirby Ultimate G Bagged Upright Vacuum?
Answer
Answer
I trying to put the shampooer on the vac. This is my first time using the shampooer!
Answer
show me what part of the kirby is the attachment to shampoo my stairs.
Answer
Ilet my Kirby get over full. The tube inside the fabric bag burst. How do we fix it, and what parts... (More)
Answer
my shampooer is only putting a stream out ing the center and not spreading the water out and not... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kirby Ultimate G Bagged...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
