Question about Autotek XS-900.2 Car Audio Amplifier
Help me hey i have an autotek xs-1500.1 stealth amp. im not exactly to sure whats wrong it but i can hook the pos and neg up and it wont do anything but as soon as i hook up the rem it'll start to whistle and the power wire going to the board will get extremly hot and start to mel the solder i cant figure it out. it'll only do it when the rem is hooked up. the only thing i can think of is that either the rem is grounding out or the relay is shorting out along the line.        please message me at
  • 631 Answers
If the wire is getting hot, the fuse in it is too large and you're in danger of burning your car to the ground.
Generally, if the amp draws excessive current only AFTER remote is applied, the output transistors have failed. If solder has melted, it may have bridged other traces and could cause more extensive damage.
Posted on Oct 28, 2007
How do you wire up 4 6 volt batteries in a 1976 kenworth. 12 volt lights 24 volt starter
When you go pos to neg from one battery to the next it increases voltage, pos to pos just increases amperage. You would want to wire 2 in series, just imagine stacking batteries in a flash light, pos from one to neg on next. Remaining pos and neg are 12v now. Run both remaining pos to starter and ground both negs. your pushing a lot of amps with the batteries and doing 12v, and your charging system is 12v. If you do another series from there, you have to regulate the voltage when the starter kicks risk burning every light and electric component...just like running 12v in 6v system... You can also use 4 12v batteries and run all pos to pos and all neg to neg and have mega cranking amps...that is how all modern big trucks are set up. Your pushing around 7k cranking amps that way(1500 per battery)...plenty to start the healthiest cat... And don't have the worry of dual voltages or running in series. You really don't need 24v to start and unless you have a 24v alternator, these are your 2 options. Best bet if your not sure is to try with risk of frying anything even on 24v system. 24v on 12v system is, on the other hand, a big risk. 43bf17ec-4e37-4a15-a147-d1e7a1377d9f.jpg
Jun 03, 2014 | Cars & Trucks
I have 2 pioneer ts-w253dvc woofers trying to hook up but they have 2 pos and 2 neg on them do i need to hook up all 4 and to what
they are duel voice coil and yes you can hook up both of them you can loop one side to the other and run one wire to the amp make sure you do pos to pos and neg to neg or you will fry your subs
Mar 16, 2012 | Pioneer TS-W253DVC Car Speaker
I got an autotek bts 7150 which is the positive and negetive speaker wires?
for stereo
speaker #1 (white = pos ,green = neg.)
speaker #2 (yellow =pos. ,blue = neg.)
for mono
white = pos., blue = neg.
Feb 22, 2011 | Autotek Car Audio & Video
I'm wanting to get the most power from my amp for the sub. Its a 2ohm dvc. If you say series or parallel I'll be confused. Need exact explanation. Thank you.
series is a straight line and parallel is is a big x. come into the connection pos and neg from there hook that to the pos and neg on one side of the dvc.on the speaker take the pos to the open neg and the neg to the open pos
Sep 12, 2010 | Car Audio & Video
I have audiobahn amp an 3 12inch subs my amp keeps kicking into protection whats my wiring opions mono amp adnot sure what ohm the subs are
Hey sound like your amp is seeing to low of indapendece. 3 subs can be hard to wire. please give mre info on the amp and the subs? dual v/c 4ohm subs are 2ohms wired pos to pos. neg to neg.
Jan 06, 2010 | AudioBahn AW1206T Car Subwoofer
Daisy Chaining 2 Mono Amps to 1 Sub?????
i beleive they have to be the same i think they have to be able to handle being strapped look into getting new amps to run it elemental deisgns i know u can strap them together an controll them from the master amp.i dont think alpines handle 3ohms that good going to check a few things an see if u can strap them two amps toghter.if u need more help email me
Oct 15, 2009 | Alpine MRP-M500 Car Audio Amplifier
I have a Kicker 08S15L72 15 dual 2-ohm need it wired for 4 ohm
ok im going to try to explain this you have 2 voice coils , i will refer to as vc1 and vc2, you take vc1 positive and connect to vc2 neg then use vc1 neg and vc2 pos to the amp according to pos and neg signs.
Feb 22, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
I bought a 500/1 jl audio amp and also a w7 10 sub
if its cutting off and right back on then check your ground and your power wire makes sure both are connected good and none of your fuse's are blown, either that or you got a wire hooked up backwards in the sub.. but my guess is that the sub is hooked up wrong... that sub should be hooked up in a series or in parallel,
ok if your running just one speaker, it should be hooked up like this and 2 speakers are a different way...
this is parallel :pos to pos , neg to neg, then one wire coming from pos on sub to pos on amp then neg on sub to neg on amp but bridge the amp on your amp should be 2 pos and 2 neg in two different channels take the pos off the sub into the pos on 1 channel and then the neg from sub to the neg on the other channel,
this is series : on the sub it will go pos to neg then the other neg and pos will go to the amp, but make sure the pos and neg r on different sides of the sub, dont hook them both to the same coil
if your need more help give me your email and ill send you a pic of how to do it...
Aug 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
one wire to pos to amp plus to speaker one. now secound speker use neg. to neg. on amp. now take a speaker wire and hook up the remaining neg. post. on the spekers. This will run them in seris like my 4000watt rms amp at a 2 ohm load. Make sur your speakers can handel the rms load of amp. If not they will blow.
Jul 19, 2008 | Car Audio & Video
Autotek XS-900.2 Car Audio Amplifier Logo
150 people viewed this question
Top Autotek Car Audio & Video Experts
Tom Chichester
Are you an Autotek Car Audio and Video Expert? Answer questions, earn points and help others
