Question about Xerox WorkCentre XE90FX Laser Printer
XE90FX Auto Feeder not detecting paper?
I try to put paper into the auto feeder but the LED light still show the scanner instead indicating auto feeder have been triggered.  I even try to hold the black trigger in the auto feeder, but nothing change, so what could be the problem? Please let me know or at least give me a service manual so I could try to probe the issue
  • Eric Tong Oct 28, 2007
    Thank for trying to provide a manual, however the manual there is only for xe 60-80, and don't include the XE90FX which have a extra auto document feeder and fax on top of the flatbed.    And my problem is those extra part.
  • 70 Answers
If you go to this site, you will need to download MULTIPART zip/rar files.  The ones that you are looking for are XE_Cover and XE_Chapter1.  When you click on XE_Chapter1, pay attention to the Multipart section.  There are at LEAST 13 files that you will have to download to get the whole manual.
http://www.eserviceinfo.com/equipment_mfg/Xerox_22.html
Posted on Oct 28, 2007
  • Justin Patterson
    Justin Patterson Oct 28, 2007
    Alright, well in my experience, typically the sensor is the culprit.  You may need to clean it, replace it, replace the board it is plugged into, or just the wires.  Without having the actual manual or machine in front of me, it's kindof hard to say.
What does ADF document mean?
"Document in ADF", usually means that there is a document in the Automatic Document Feeder. Or to put it differently, there is a paper jam in the document feeder (probably of the scanner part).
The fix is to check the feeder and clear the jam. Sometimes it indicates there is a piece of paper stuck or a faulty paper detector.
Dec 26, 2014 | Office Equipment & Supplies
I get the message that says "no paper in auto
Not sure if you get this message on the machine or in the software on you PC. It could be a software setting if it's on the PC that tells it where to pull the docs from. If it's a scanner message it could be an object blocking the paper sensor telling it something is in the feeder. Check the feeder paper path for anything that does not belong there or carefully blow out the paper path with compressed air. Sometime dust collection does this.
Feb 03, 2011 | Xerox DOCUMATE 510 Flatbed Scanner
The printer keeps telling me it's out of paper, which it isn't
1> Open the sheet feeder cover and pull out the paper support.
Set paper, aligning the right edge of the paper to the cover guide with the paper's print side facing up.
Pinch and slide the paper guide to the paper's left side.
Note: Make sure to set paper lengthwise. Setting Credit Card sized paper long-side down by mistake may cause a paper jam.
Pull down the paper output tray supporting with both hands.
Pull out the extension completely.
Ensure that the Power lamp and the Auto Sheet Feeder lamp light.
Note: If the Cassette lamp lights, press the Paper Feed switch to light the Auto Sheet Feeder lamp.
If the Auto Sheet Feeder lamp does not light even after pressing the Paper Feed switch, Paper Source in the printer driver may be set to the setting other than Paper Feed Switch.
Nov 11, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Paper out canon pixma ip200
Either you have selected the wrong feeder, it can feed from the back or the front tray, the little green light shows which tray is selected. If you have paper in both, the feed roller may need cleaning since it gives that error if paper doesn't get picked up.
Sep 01, 2009 | Canon PIXMA iP2000 InkJet Printer
At scaning time show
Hi
I take it the scanner is connecting to your pc okay? the paper need to engage in the feeder. Try just putting one piece of a4 copy paper in the scanner and seeing if that will register as beng paper in the document feeder.
Kind regards Liz
Feb 19, 2009 | HP Scanjet 7800 Pass-Through Scanner
My brother laser printer HL-5050's paper light is flashing, which usually indicates a paper jam. i've checked 5 times and there is no paper jam. have shut off printer and restarted 3x. when i try to print,...
Hi
I've nearly the same problem....My printer(HL5050)  takes only a little bit of the sheet, then paper led flashes.
I've found a block into the paper feeder. This printer is impossible to disassemble.!!...even if I've the service manual, because for taking away a simple pressed paper block , it's necessary disassembling  almost all the machine!!! No comment
So I'd an idea:
I've sprayed into the paper feeder a great quantity of a cleaning spray (without oil) , in order to get the paper block wet, then , by means a school-book plastic cover, used like a paper sheet,  and  manually acting on the gear, I've pulled this plastic sheet up and down several time (spraying in the same time)in order to  remove these hard paper blocks. Now my feeder seems free. Tomorrow I'll try to test it.....
Regards
PS To do this it's necessary the only removal of left cover, in order to reach the gear which allows the paper to advance manually.
Apr 21, 2008 | Office Equipment & Supplies
HP LaserJet 2840 Scanner problem
Have you looked to see if there is any paper at all in the trays. That are getting hung up.?? I can help
Feb 10, 2008 | HP LaserJet 2840 Printer
Paper tray selection
Go to Paper Menu > Paper Size > Tray 1 - note what the Auto setting states (Letter, A4, Legal, etc.) Pull the tray out to set what it is configured for. Then reinsert it & pull it out a few times, noting what the display show the Auto size show. It should match the tray's settings.
If the Display indicates otherwise, it means one of two things:
1) The "auto size sensing" board on the left may be defective. The left side of the tray has a matrix of 3 plastic tabs that stick out in certain order depending on the tray setting. If this board fails, it may show Executive or A4 when the tray is set for letter.
2) The tray may be in-between two settings. Try to readjust the tray length setting between sizes. (You will notice the plastic tabs will change order.) The last time you loaded paper it may have pushed it just enough so that it is no longer seen as letter by the auto sensing board.
I hope this helps...
Nov 28, 2007 | Lexmark Optra T610 Laser Printer
Copier Orientation
clean the three paper selection sensors on the feeder.better you select the paper tray according to the paper orientation instead of using auto paper slect function
Nov 21, 2006 | Ricoh Aficio 2027 All-In-One Laser Printer
Xerox WorkCentre XE90FX Laser Printer Logo
82 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
