Question about Epson Stylus Photo 1280 InkJet Printer
Brothers 5-1 lasar multicenter
I am having trouble with ink all smudged on the paper, front and back. I bought a new drum and ink cart. but, the copies are full of ink. thanks donna
  • selbywoman Nov 06, 2007
    Hi, it is a brothermFC7420. i bought all new brother products. I am sorry I did get a toner instead of ink. I am still having problems. I will try half way through and see what it does. I have spent $75.00 to haveit cleaned. Thanks
  • Epson Master
  • 1,113 Answers
What model - Epson under heading. Brother as you speak, you speak of ink but also of a drum, machines that use a drum dont use ink. they use toner, so I guess you have a Brother MFC ???? ie 8820. Did you buy gen Brother Drum and Toner?
Is the insides of printer clean or full of powder?
Is there any image?
Stop a print halfway in machine and see if mark only occurs after paper has traveled threw the fuser (the hot bit at rear)
Posted on Oct 28, 2007
There is a horizontal line grey in color
If this a P2035 printer using a toner cart with a drum in it. The drum has been exposed to light or has a smudge on it. take the cart out and look at the drum. This is a round light blue tube located at the bottom of the cart. It is the drum because it is the only thing in the printer that will print a defect three times on the paper. You could also print about 0 black sheets of paper through the printer and it will go away. This is because the drum coating is in layers like an onion. You must get rid of the exposed layer to get to on that has not been exposed to light.
Apr 02, 2014 | HP P2035N LaserJet Monochrome Printer
Hallo I have a problem with my EPSON sx415. I bought new analog ink cartridges (not genuine). I puted it in my printer and tryied to print. But paper was white. So I decided to clean printers head with...
you will have to spend more money my friend! the epson ink is called durabrite, the cheaper cart you got is water based, the head should have been flushed before hand to remove the durabrite ink, what has happened is the 2 types of ink have mixed in the head and set. the only way to fix this is to remove the head from printer and have it ultrasonic cleaned, i had the same problem and tryed cleaning products with no affect! the only wat is to get it ultrasonic cleaned, or if you have the epson carts, put them back in and try and get it exchanged if still under a year old. as a new head is about the same price of the printer, however argos has the printer on offer at this min for only £39.99 which is cheaper than ink. oh yea, the reason that the printer is now not seeing the carts is that doing back to back cleans emptys a new set of carts after only 5 or 6 head cleans so your new ink is now useless, sorry for the bad news.
Dec 24, 2010 | Epson Office Equipment & Supplies
Black line, 4-5 mm thick, down the page on printing, off centre
ok, both of those solutions are totally bogus....first, the quality issue...i build about 25 of these cartridges a week, and it sounds like you should check the life of the drum unit, if you haven't cleaned the corona wire already. ( refer to the printer documentation) Brother uses a seperate drum unit that will wear out after 12,000 pages, not the pickup roller. So if you have replaced more than 4 toner carts, it is likely, depending on your usage, that the drum unit is worn. Take out the whole toner/drum unit, remove the toner cart by pressing on the lever on the left front of the assembly and pull up and out. Now you should have two pieces. Look into the larger piece, and if you see excessive wear on the drum, it needs to be replaced. The jamming is a different issue, though....let me know if you need more info....don't buy a new printer yet!!!
Jun 11, 2009 | Brother MFC-7420 Laser Printer
Brother MFC 7820N Smudging Concern
If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pagessettings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Sep 11, 2017 | Brother MFC-7820N All-In-One Laser Printer
4 - black ink smudges (1/32" wide x 1/16" high) in right margin
Very nice trouble shooting. The image defect you describe point to the OPC or drum unit this is essentially the toner cart. In your case black. Measureing the distance between repetitive defects is a sure way of diagnosing problems such as yours. Again nice work.
Google repetitive defect ruler for your model to help in the future.
Hope this helps
Apr 07, 2009 | HP Color LaserJet 2600n Printer
After paper jam, prints total smudge on Intellifax 2800...please
This is the test to determine toner/drum or fuser issue.
Print a test page
When you hear the paper feed into the machine open the top to stop the machine
Remove the toner/drum cart.
You should be able to see the page with printing on it. (This is before the page hits the fuser)
If you can see the smudge or marks on the page the problem is most likely the cartridge but NOT the fuser.
If the page is clean the problem is most likely the fuser.
Mar 13, 2009 | Brother IntelliFAX 2800 Laser Fax
Black Smudge of ink along top edge paper Brother Intelifax 2800
try cleaning the grid on the drum unit otherwise there could be some thing on the fuser preasure roller.
Jan 16, 2009 | Brother IntelliFAX 2800 Laser Fax
Blue color smears on every page
If you're still getting smudges, there must still be a label or part of a label either on one of the image drums or the transfer belt, i've found in the past it somethings gets stuck inside the unit on the cleaning blade. What i suggest is you run a print and open the front door at the paper travels along the transfer belt, look at all the image drums and see if you can see the smudge on one of them, if so the problem is caused by that cartridge if not it's in the transfer belt somewhere. You may need to try stopping the printer a few times and if the problem is in one of the cartridges, you will mst likely have to replace it, as with the transfer belt if you think that's causing the problem it's easier to remove it and rotate the belt manually.
Please note the image drums and the transfer belt are all light sensative
Sep 02, 2008 | HP Color LaserJet 2600n Printer
LCD show "NO CARTRIDGE" after installing new ink cartridges...
next move: give to back due to guarantee. there is nothing what you can do!
Apr 08, 2008 | Brother MFC-5860CN InkJet Printer
Empty Ink message
Try this 1# :
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000300/000036/faq000336_002.html?reg=us&c=us&lang=en&prod=mfc420cn_us
If you still have trouble:
unplug machine from power. Open cover and take all carts out of position. Plug machine to power again by connecting it to the wall socket. Wait until machine has done start up. When finished power on machine (if it has shut down first). Machine demands carts. Place each demanded cart into position and make sure it is secured. Answer lcd display questions. Close cover. Machine will run a cleaning cycle and come up stand-by.
If you still have trouble after that procedure, use another ORIGINAL cart. (Most brother printer  trouble is because of diffrent construction of generic ink carts and due to wrong ink).
And if there still is trouble have a look at the led control circuit board built in the cart holder it should look this:
Dec 21, 2007 | Brother MFC 420CN All-In-One InkJet...
Epson Stylus Photo 1280 InkJet Printer Logo
83 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
