Question about Toshiba TP55G90 55" Rear Projection Television
Screen removal I have a Toshiba TP55G90 rear projection tv that has a pushed in front screen. How do I remove the front screen housing and return the screen to the original condition?
    Genius:
  • 1,694 Answers
1) Remove lower,front speaker grill
2) Remove screws along bottom edge of screen frame
3) Lift screen assembly off cabinet
4) Lay assembly face down
5) Remove just enough frame screws to get back in position--
    Don't force it----
6) Reassemble.........T.
Posted on Oct 28, 2007
How to clean inside a toshiba theater view rear projection tv?
you can remove the screen but there is a easier way, from rear with cover removed use a swiffer cleaner to get at the webs etc. Gently.
Nov 27, 2012 | Toshiba TP50H50 50" Rear Projection...
INNER SCREEN NEEDS CLEANING
Here is a picture that shows you how to remove the front screen to get access to the mirror as well.
Aug 15, 2008 | Toshiba 51H84 51" Rear Projection...
How due you replace the lamp in the Toshiba Toshiba 65HM167 65 in. Television
Pop off the front panel below the tv screen. Remove bulb cover door (screw) and then remove the bulb housing. Replace with new bulb and reverse the process.
Thank you and best of luck!
Jun 06, 2011 | Toshiba 65HM167 65" Projection Television
Toshiba TN50X81 Lens Cleaning
Usally access from rear panel, unplug and only wipe the lens with feather duster. do not mechanically move the projection tubes or you will effect the convergence of the 3 colors
Jun 17, 2009 | Toshiba TN50X81 50" Rear Projection...
I have a toshiba 50inch rear progetion tv. I was
There is one mirror inside. It is easy to remove the front plastic screen by removing the bottom fabric grill (snaps off by pulling outward like a removable speaker grill). Remove several wood screws along bottom edge of screen. Lift up the whole plastic screen frame and pull it away from the TV; but be careful with the control wires that go to the center panel, which snaps off the big screen frame easily. The mirror is right there.
Apr 01, 2009 | Toshiba TP50G60 50" Rear Projection...
Would like to remove screen.
Easier to remove the top back cover, be carefull it`s heavier than it looks, has a large mirrror on the inside of the cover, hope this helps, video-tek
Feb 01, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Re-install TV screen
yes my friend, just pull hard on one of the sides and the front housing start to come off
caypianan@yahoo.com
Oct 12, 2008 | RCA HD52W58 52" TV
Power light is blinking TV does not turn on
Mosy likly the regulator Ic in the main power supply . Not a consumer replaceable item because of xray and safty issues Call in a shop to assit you in this matter. Good luck
Jun 14, 2006 | Toshiba TP55G90 55" Rear Projection...
Televison & Video Logo
602 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
