The inside door lights stay on and drain the battery. How do we fix this problem?
Remove the bulbs from the doors to stop the battery from going flat then check all the door light switches as it sounds like you have a switch that is still allowing the power to get through to the lights hope this helps
Check all doors for a sticking door open sense switch. Check all over-riding interior light activation switches are off. If all the above are ok, check for a sticking interior light relay.
Thank you both so much. I will check it out!
