Ph30hqs. Fan touches shroud right when turned on and as it's slowing down when turning off. Makes a loud noise but I can't find a way to get to the fan or see it. No easy access panel screws to be found to get up there. Help please!
SOURCE: Fan light flashing on thermador vent hood model HNW36YS
Grease Filter Saturation LED The speed 2 LED in Figure 1 in is marked with an F. This LED will flash to remind you when the grease filter needs to be cleaned after 40 hours use. Follow the instructions for cleaning filters in thisFollow the instructions for cleaning filters in this booklet. Once the grease filters have been cleaned, reset the display by pressing button A for
SOURCE: My thermador stove fan keeps going up and down cvs45r
no
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
SOURCE: I have a 1989 model
check in the hood pipes for a rubber seal thats come adrift as something isloose or come apart allowing the hood to come too low so it passing the microswitch for the fan ,between teh tubes is a seal and suspect that one of these has collapsed allowing the hood to come down lower ,its a take it apart type job and see ?
