I have a 2010 Isuzu Dmax LSU Auto. The gear lever won't come out of park (P). I have checked the fuses and it keeps blowing (C4-Back light). If I replace the fuse the problem is fixed until the fuse blows again. The gear position display in the dash also disappears when the fuse is blown.
SOURCE: No parking lights, fuse keeps blowing.
There is a ground not connected or a wire open that is causing it to blow
SOURCE: 2004 nissan titan, shift lever
Hello gary823
Thank you for choosing fixya.com.
First things first: I suggest taking your truck to a mechanic or an auto parts store that can do a diagnostics test done. If any fuses or relays are blown, this test should bring up any codes that would indicate any type of malfunctions.
The shift lever being locked: In newer vechicles, the brake pedel, as you know must be pressed in order for the transmission to be put into gear. There should be a sensor on the transmission that runs in cahoots with the brakes. This sensor tells the computer what gear the transmission is in. It is very possible that at the last time you put the vehicle in Park, that the switch had it's final moment of ability. If the sensor is in fact useless, it may be the reason the transmission is locked into Park. It may be the reason why the brake lights aren't working; and why the brake lights fuse is blowing. Also, check all relays, (can be tested with a fuse tester) and make sure all relays are good as well. Make sure also that the light sockets for the brake lights, tail lights, back up lights, and front running and blinker lights are in good condition. One faulty socket, can cause more than one bulb to blow, or cause fuses and relays to blow as well. Follow the wiring for the brake lights for as far as you can to ensure there is no damage (melted, broken, etc.). This could also affect fuses. This truck I see is barely 5 years old, but you'd be surprised how quickly parts and wiring and such will go bad, or wear out and/or just quit working.
If the transmission sensor is not the problem, and all fuses and relays are good. tranny fluid is full, check the linkage under the truck. It may be jammed somehow, or stuck. On the transmission, where the lever inserts, there is a seal - inside that seal, there is like a gear that the lever pushes in order to shift from gear to gear etc. You may need to have that checked out to make sure it's not broken inside. If your fluid is low, or empty, you may have froze up your transmission, however, you most likely would have been seeing large amounts of fluid in the frequent places you park. Another think to check is your differentials. Make sure the fluid is full in each, as well as the seals not leaking. The seal sits just inside the inner most part of the pumpkin (differential ball) where the yoke is inserted. Maybe you have just locked up the rear driveline. Check the seal on the front end of the driveline as well, (goes into the rear of the transmission (yoke). Check your U-Joints as well, making sure they are intact, tight. It may be a good idea to have them replaced if they look supsicous in any way.
These are all the things I can think of that would make your truck be stuck in park, and make your lights not work, and blow fuses.
I sincerely hope this information is useful and aides in the successful repair of your truck. Thank you again for choosing fixya.com. Please let me know if I can be of further assistance, or if you have any more questions or concerns (comments).
Thank you again,
carsandcomps
Guru, fixya.com
Oregon
SOURCE: BMW E36 Auto gear lever
its a bit fidly , ther is a screw under the plastick trim on the gear knob its self and then it should fall apart from ther .. you should be able to get a new one cheep from bmw . or fix yor self as all it will be is the spring has gone . sorry i cant be a bit more help but its hard to explain , but easy .
Hey mate did you ever get this sorted I have the same issue in my 08 dmax?
