Question about Lexmark X5470 All-In-One InkJet Printer
Automatic document feeder doesn't wotk.
The ADF pn my HP 6110 stopped working.  It won't pull any pages through to be copied, faxed, etc. I get a  "Reload document, then restart job" message.  i have tried cleaning the rollers and pad with isoprpyl alcohol, but it doesn't help.
  • 10 more comments
  • QueenMum Nov 07, 2007
    I have a HP Photosmart 7660 printer with the same problem. I did the same thing. The printer makes the sounds before printing but does not feed the paper through and then it says: out of paper. I followed the suggestion at hp.com to clean the rollers in the back but that did not change the problem.
  • Anonymous Jan 22, 2008
    Printer Lexmark X5100 series. Will NOT sent the good photo paper through to print the picture. Will print on plain copy paper, which I don't particularly want.
    ML
  • JanetL1077 Feb 17, 2008
    Having the same issue w/ours. It jammed yesterday on a sheet of paper and once I pulled it out it stopped printing. For a while now it's been saying it's also out of ink even though we replaced the cartridge. Now it says it's out of paper when it has some in there. We bought this one almost a year ago, but we barely use it. No way we can return it now. Not sure how to fix???
  • Anonymous Mar 12, 2008
    feeder won't pull paper thru......then 'out of paper' comes on
  • Anonymous Apr 19, 2008
    wipro 2050 printer
  • hjs1 May 05, 2008
    The adf on my fax machine will not pull any documents through.
  • Logarian May 22, 2008
    Won't feed quality photo paper how do you clean the rollers? I think that may be the problem its fairly new but just the same..
  • jayfp Jun 18, 2008
    ADF pulls paper in to second rollers then sounds like gears not meshing and no more paper movement. Have cleaned all accessible parts. Have taken parts off to access internal rollers with out success.
  • fayecutlip Sep 07, 2008
    the paper jams everytime and will not feed through
  • Anonymous Nov 11, 2008
    The ADF on my HP Officejet Pro L7590 will only feed the document half way, then get stuck. I have tried removing and cleaning all accessible parts.
  • Graywolf212 Nov 16, 2008
    I have the same problem, but it's on an officejet 7210xi. Paper feeds half way, then I hear what sounds like a gear spinning real fast and I get 'Scanner Failure, Power Off and On'. I've done everything on HP's website to no avail.
  • sdgcc May 23, 2009
    Same problem but on the HP Officejet 5610. So frustrating!
I have an HP 6110, when I try to scan; the paper is pulled all in the left side. Can someone help? I try to clean the mirror but without luck.
Posted on Feb 06, 2011
    Problem Solver:
  • 24 Answers
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
894
Posted on Mar 02, 2009
What is adf
Hello!
An automatic document feeder or ADF is a feature which takes several pages and feeds the paper one page at a time into a scanner or copier, allowing the user to scan, and thereby copy, print, or fax, multiple-page documents without having to manually replace each page.
Aug 15, 2017 | Office Equipment & Supplies
Document feeder mispick.reload
Clean rollers in the ADF (automatic document feeder) with methylated alcohol for quick fix or replace the roller assembly
PN: 5851-2559 and seperation pad PN: Q2665-60125
Dec 24, 2013 | HP LaserJet 3055 All-In-One Printer
Xerox documate 752
Your document must be in place/position to be scanned, faxed, etc.
Place document, then scan. ADF is your automatic document feeder. Used when copying/scanning multiple pages. Reload and try again.
Aug 29, 2013 | Sewing Machines
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
I want to fax a document
Hi
To send a fax from your hp officejet
Follow these steps to send a fax from your HP OfficeJet.
1 Load your original.
Note: You must use the automatic document feeder (ADF) for multi-page
faxes.
2 Enter the fax number using the keypad.
3 Press Start Fax, Black or Start Fax, Color.
Oct 26, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I want fax a document
Hi
faxes.
pls vote me i help you
Not scanning or copying when using the ADF on HP laserjet 3055
Based on the assumption it's mechanically ok, check the cable connection between the document feeder and the base, if damaged or worked look it can cause errors. If it is a sensor error, check for a small bit of paper or even a staple from a prior jam.
Jun 18, 2009 | HP LaserJet 3055 All-In-One Printer
My HP printer paper get stuck in top feeder whenever I try to fax
Lift the cover to the ADF (Automatic Document Feeder) and remove any paper debris from the rollers. Also, clean the rollers with a very damp cloth and a dab od dish washing detergent.
Also, check to see that the spring loaded lever is in place.
Clear the jam from the automatic document feeder (ADF)
  1. Make sure the product is turned off and the power cord is unplugged.
  2. Grasp the upper edge of the automatic document feeder (ADF) assembly and open it.
  3. Raise the roller assembly.
  4. Gently remove any jammed paper from the ADF.
  5. Lower the roller assembly.
  6. Close the ADF assembly.
  7. Plug the power cord back into the product.
  8. Press the Power button (c01346625.gif ) to turn the product on.
  9. Try the print job again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 01, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Top feeder won't work properly
hello!
have you tried cleaning the separator pad inside the automatic document feeder?
try to Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
If the problem persists, clean the rollers and separator pad manually
May 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Office Jet 6110 All in One faxing
This document covers the basic fax functions of the HP Officejet 6100 series. The HP Officejet 6100 series can perform the following functions:
  • Send and receive paper faxes.
  • Send and receive color faxes. Color faxes can be sent only to color fax capable machines. If a color fax is sent to a black-and-white only fax machine, the HP Officejet sends the fax in black and white.
See Figure 1 below to identify the buttons in the Fax area of the front panel. Figure 1: Identifying the fax area of the front panel c00259777.gif 1- Turns Auto Answer on or off 2- Scrolls through speed-dial entries 3- Redials the most recently dialed number 4- Dials fax numbers, enters text, and specifies menu items. 5- Starts a fax 6- Changes the fax resolution 7- Dials one-touch speed-dial numbers Fax settings Most fax settings are configured during installation through the Fax Setup Wizard. These settings, and some additional options, can be accessed through the front panel menu (see Figure 2). Figure 2: Changing fax settings from the front panel menu
1. Menu: enters the menu system.
2. Right and left arrows: navigate the submenus and options.
3. Enter: selects a submenu or option.
4. Cancel: exits from the menu. c00259778.gif Sending a fax To ensure the best quality when sending faxes in color, use a color original instead of a color copy. Follow these steps to send a fax:
  1. Load the original. Load originals directly on the glass or in ADF. For multi-page faxes, you must use the automatic document feeder (ADF). Loading original on the glass Place the original, print-side down, on the front-right corner of the glass. Loading original on the glass c00259779.gif Loading original in the ADF Place the original, print-side up, in the ADF. Adjust the paper-width guide to fit the original. Loading original in the ADF c00259780.gif
  2. Enter the fax number using the keypad. Dial the number just as you would from a telephone (dialing 1 before an area code, etc.)
  3. Press Start Fax Black or Color.
  4. If there is no original in the ADF, the display will read, "Send from Glass? Press 1 for Yes or 2 for No"
    • Press 1 to scan the document from the glass.
    • Press 2 to load the document in the ADF. The display will read, Load original, then press Enter .
Apr 15, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Lexmark X5470 All-In-One InkJet Printer Logo
1,154 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
