Question about HP Pavilion dv1000 Notebook
Wont boot into windows
Powers on, boots through the post, get to the option screen to start wondows normally or through safe mode etc but doesnt go any further????
has the hhd failed?
any help be great
  • 1 more comment
  • matyw Oct 28, 2007
    no doesnt boot to safemode either......
    hard drive test comes back with fail #1 07
  • Jason Yang Nov 30, 2007
    Hi, I'm also running into the same problem on my HP Pavilion dv1000. None of the Safe Mode options are working - if I click try them, the system just restarts and comes back to the same thing. I tried the F10 suggestion, and I ran the Hard Drive test. Within maybe 30 seconds, it said: "#1-07 Fail." Does that mean hard drive failure? As in I can't even go in and reformat it at this point, and that I would need to buy a brand new hard drive and install it?
    Thanks for the help!
  • smashly Dec 01, 2007
    computer won't start tried to reboot and do test drive and the test failed. Now what?
    Problem Solver:
  • 12 Answers
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Posted on Jul 23, 2010
Buy a new hd, the old one is fucked...
Posted on Nov 10, 2008
I just having the same problem wiht my notebook
but if I going to the boot-menu and wont to run the "self dive test" then it's just telling me s.th. about "fail # 1 - 07".
I also tried to start at the other Disk that also don't worked.
what kind of problem is it?
Is it an software (form Running System) or form Hardware (Disk by it self)???
Dos it will work if I will reinstall my office-system(<--you will know what I mened)????
Thanks for you help.
Posted on Dec 19, 2007
Hi I'mjust having the same problem,
if I try to start the "self hard drive test" the it is just telling me:
Fail #1 - 07
It's need about 30 sec. but nothing (<--you will know what mend)
happening....
so can you give me an simple advise for that???(pleeeeeeeeease).
  • 47 Answers
Have you attempted to run in Safe mode?  Does it boot there.  If you boot to safemode and it locks on MUP.SYS most likely just the OS needs reinstalled.  Go in to CMOS (F10 on boot I think) and under tools there should be a hard drive test.
Hope this helps
Posted on Oct 28, 2007
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Booting problems
Can you get to ANYTHING? Safe Mode? Recovery? Restore? Command Prompt? Unplug, remove Battery, leave battery out, plug in, try to boot. post results. Do you have a repair disk?
May 06, 2013 | Dell Inspiron E 1405 1505 1705 PA10...
When i start my Notebook (HP mini 110 1034) it goes to a black screen with my password requirement and when i enter my pasword it doesnt go to my regular startup page. It doesnt let me boot even with my...
Start you're computer on safe mode an run you're antivirus
Using the F8 Method:
  1. Restart your computer.
  2. When the computer starts you will see your computer's hardware being listed. When you see this information start to gently tap the F8 key on your keyboard repeatedly until you are presented with the Windows 7 Advanced Boot Options screen as shown in the image below.
  3. Using the arrow keys, select the Safe Mode option you want.
  4. Then press the enter key on your keyboard to boot into Windows 7 Safe Mode.
  5. When Windows starts you will be at a typical logon screen. Logon to your computer and Windows 7 will enter Safe mode.
  6. Do whatever tasks you require, and when you are done, reboot to go back into normal mode.
Jul 19, 2011 | Computers & Internet
How do i turn off safe mode
Most computers when you boot it up give the option of "Boot Menu" upon the first few seconds of powering the machine on. Look at the screen and see if it reads Press F1 or F2 for Boot Menu. From there you can toggle off the safe mode option. Sometimes it's the delete key or alt key for some other computer providers as well.
Hope this helps,
Marty
Nov 27, 2010 | Computers & Internet
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
Laptop wont even attempt to load windows??
With this kind of problem, you must put in the Windows software disk and boot. Then select repair Windows from the list. This option will attempt to correct the problem.
If you do not have the disc, boot into the repair / diagnostic mode from the boot screen. See if there is an option to create boot disks.
Jan 04, 2010 | Toshiba Satellite A70 Notebook
Getting out of the initial set up
First try to Boot to Last Known Good Configuration.. do this by pressing F8 upon bootup...look at the prompt screen for the option mentioned OR
Attempt to boot up in Safe Mode....
Do This by pressing F8 Upon bootup, it will take you to a black Safe Mode Options screen... once there choose the first option.. boot into Safe Mode Only.. If you are able to boot into windows that way,, you can then check for problems... Like checking the device manager for errors, Check the Status of your hard drive.. etc.
Jun 04, 2008 | Dell Latitude C400 Notebook
Black screen comes up "windows did not start successfully...." choose from safe mode, safe mode with networking etc Last known Configuration or Start Windows Normally. Computer then tries to...
You should opt Safe Mode:
  • On the black screen just navigate throug up and down arrow keys.
  • Goto Safe Mode and press enter.
  • It will boot your system in safe mode.
If the boot is success full:
  • try to remember any software or hardware you recently installed/change. Then remove/uninstall that software/hardware. Also remove some device driver like Video/Audio driver and make re-start. and try to normal boot. If success then install your audio/video.
If no success then I think its time to re-install your windows.
Please post your feed-back.
Gud Luck
Iqbal
Apr 20, 2008 | Computers & Internet
I have a Packard Bell Imedia 5106. I want to start it in Safe Mode so I can run a virus scan and basically clean it up. I have tried tapping F8 when I switch on. This takes me to a boot screen with three...
hmmm its seems your first F8 takes you the boot menu option of BIOS not one of the windows.
So, after selecting first option again press F8 it will bring the windows boot menu options.
You can also do one thing but it might currept your operating system, even if you want to try just start booting and as well widows goin to load press and hold your power switch till you PC goes power off. So since windows did not load properly, when you will boot it automatically brigs the boot option screen to select Normal or Safe mode.
Thanks
iqbal
Mar 22, 2008 | Computers & Internet
HP Pavilion dv1000 Notebook Logo
619 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
