could be a fuel pump or a fuel regulator or a cam shaft belt broken or an immobiliser not operating or a flat key battery or an empty fuel tank or 100 other things. When you have a problem the first thing is to run the fault codes to get the recorded faults from the CPU and then you will know exactly in what areas you have to look. So run the fault codes and let us know what you find so that you can get advice on how to fix it.
Please turn off the computer, start hitting F8 at the start-up and then
choose last known good configuration. If this does not work, choose Safe
mode options. If still does not work, please try to restore the
computer to factory settings. You can try to hit F11 or F10 at the
startup to initiate recovery. system recovery will delete all of the data/file and software installed on the computer.
Some times the pots that you may be using are not designed for use in induction cooking. If you are, It might be the size of pot. The peeping sound might be the cook top looking for the pot. But when all else fails. Turn the stove off at the Breaker count to 12. Turn back on. Reboot. Hope one of these work.
OK the electric doors do not lock and your cruise is inoperable. You have a "peeping" on and off ? Did you mean to say BEEPING ?
I would check the fuse first, if not that then a relay. As far as the beeping you hear, do you have a security system on the truck ?
Please let me know.
Hi, my device wan't start. Console is lighting, but only few touch knobs makes sound "peep" and "peep - peep". Manual knob is lighting RED. Unfortunately I can't start it. Can you give me advise for this problem?
