Question about Kenmore Freezer 20.3 cu. ft. Frost Free Upright Freezer
Kenmore Upright Freezer 253.21741104 Loss of Power
Over the past 4 years or so, my Kenmore freezer has lost power about 4 times, losing all the food being stored.  All I have to do to "reset" the freezer is to unplug it, wait a few seconds, then plug it back in.  The freezer runs for about 6-9 months reliably, then unpredicably, it will againt shut itself down for some unknown reason and stay off until I discover the situation.
Could this be a bad circuit board?  Does this freezer have a circuit board?  Anyone seen this problem and if so, how did you solve it?
  • 1 more comment
  • Nick G Oct 28, 2007
    Thanks for the speedy reply (less than 24 hours, just awesome). Looking forward to your update!
    Any tips with replacing the board will be most appreciated.  I take it the new boards are troublefree?
  • Nick G Nov 01, 2007
    I checked the serial number of the unit and it starts with "WB229" so based on your information its a bad circuit board.  I just looked from the Front of the unit and what looks to be the board is high up near the right side of the compressor (looking from the front).  The board  looks like a small relay about 2" X 3".
    I'm going to call Sears and see if they will fix it. Worst case I can replace it myself. I assume this will fix the problem.  Thanks for your help, especially with the recall info.
    This is my first time using FixYa and it will save me 300-400 bucks assuming this solves the problem.  Nice service.
  • willie59 Nov 05, 2008
    I am having a simular problem with upriht freezer allthough it is a 13.7 cu unit purchased in may 2006 # 253.26242100. Also displaying E on the temp indicator.
  • 290 Answers
Yes, it does have a control board. It is located under the rear of the freezer near the compressor. There was a service bulletin out a few years ago about the exact problem you are having. I will not be able to find out if your freezer falls under this design change until tomorrow when I get on my computer at the shop.
What is happening is the board has a fault in it that won't allow it to come back on sometimes if the power blinks off and back on. I am not sure if the repair credit is still active but we have changed the control boards on many of these units free of charge as recently as a year ago.
I will reply back when I find out for sure.
Posted on Oct 28, 2007
  • 1 more comment
  • Michael  Lindley
    Michael Lindley Oct 29, 2007
    I found the service bulletin today. The recall is SF46-479.
    I covers the serial number range WB215 - WB234. If the first three numbers of your serial number fall anywhere between 215 and 234 you are part of the recall. I found no letter stating they have ended the recall so it should be repaired at no charge to you. You can make sure the new kit has not been installed by moving the freezer out and looking at the control board mounted to the bottom of the freezer just above and to the left of the compressor. If it has a green circular sticker on it, it has been replaced. If not it needs to be if your serial number matches what I gave you.
    Check this out and let me know what you find. The new boards have not given this problem that I am aware of so you should be in good shape.
    If you do fall under the recall, call sears and sears and give them the information I gave you and get a call set up.
  • Michael  Lindley
    Michael Lindley Oct 31, 2007
    Just wanted to follow up on your freezer and see what you found out.
  • Michael  Lindley
    Michael Lindley Nov 01, 2007
    Thanks for the reply
    I don't think you will have any problem. There were letters sent out when the recall was first announced with a special phone number to call but some people were missed as you can expect with several thousand machines nation wide.
    Good luck.
Whirlpool Gold Resource Saver GI6FDRXX- do you really have to manually reset if you lose power?
L oIf you are out of town, the freezer will keep contents cold for 24-48 hours. You can have a neighbor check on it while you are out of town, or you can take the food to a neighbors house, or you don't go at all. Think about this, you can't stop enjoying time away because the freezer may go out. What would you do if the water line broke in the house. The likelihood of that happening is greater than the freezer going out . Go and enjoy yourself. It likely won't happen again.
Feb 23, 2013 | Whirlpool Gold Resource Saver GI6FDRXX...
Freezer not freezing
If you can hear the motor running it could be the thermostat that has gone or if there is no noise at all it could be the motor that has died, a good easy fix ( sometimes works ) is to turn the freezer off leave it for 24 hours with no power then try turning it on again.
Apr 22, 2012 | Kenmore Freezer 20.6 cu. ft. Upright...
1991 Kenmore 16 model 253 in storage for 7 years. Plugged it in and turned it nn last night and seemd to run fine, nice and quiet just like before. Today it is not cold and the comressor seems to be r
If the freezer was stored and not running for 7 years it may have lost coolant.  Since the compressor is running recharging the coolant may fix the problem.  Hot compressor might indicate low coolant since its motor is immersed in it.
May 30, 2009 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Running non stop!
Sadly these old freezers use way too much electricity. You will be better off junking this one and purchasing a good used or brand new one.
Apr 02, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Working ff freezer unplugged 1 year now does not freeze
Hi!!! You seem to have a seal system problem..A leak of refrigerant or a restriction in the seal system..Good luck...
Jan 20, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Kenmore Chest Freezer C675-18012-1G purchased april 2000
Average freezers last for several years, usually 10 or more. The compressor should not run all of the time, maybe less than 10 to 20 percent of the time if it is working properly. Not sure what you mean by the bipass, some freezer have a manual defrost, and in this mode it will not cool. Insure the location where you have the freezer allows for ample air circulation, sometimes folks put them in little spaces that prevent air circulation to the condensing/compressor unit and they overheat and do not work well and fail very quickly.
Nov 27, 2008 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezers Logo
766 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
