Question about Intel Motherboard
Problem for D101G Intel Mother Board
Dear Sir,
                 I have a Intel original D101Ggc mother board with P4 2.66 processor. Recently I face a problem in my machine. After staring the P.C ram test is ok, after that stating windows XP the scroll bar is coming for starting of winXP.But nothing happen it just restart againg.The same thing happen when I start it in safemode. So that I think it is the cause of winxp prof.And I want to reinstall it, but in that time when I want to create a fresh install, after formating the machine it there is a message, that it can't copy some files,after 7% percent of file copying.So that I change the CD and also CD-Rom drive. But nothing can change. My DDR1 400 BusSpeed Ram are ok. I checked it in a diffrenet machine it is totally ok there. I changed harddisk also.But same thing was there.
                  Please suggest me some alternate solution. And please help me how to solve the problem.
                  Thanking you,
Yours faithfully Partha Banerjee
email-banerjeepartha2001@yahoo.com
  • babloooo Mar 26, 2009
    sir am veeresh from hyderabad i have some problem with my INTEL mother board my serial num BTNL727026Z2 AA 097184-102 IT IS NOT DISPLAYING ANY THING ON SCREEN MY DATE OF PURCHASE IS ON 25TH AUG 2007 IT IS UNDER WARRANTY ENQUIRED FROM WHERE I HAD PURCHASED THEN TOLD TO SEND EMAIL ON OLINE BUT I DONT KNOW ABOUT THAT COULD U PLEASE EXPLAIN ME OR CAN I HAVE THAT SERVICE CENTER NUM R HOW TO CONTACT THEM
    HOW TO SOLVE MY PROBLEM MY CONTACT NUM :9291571445
    EMAIL:babloooo.12011988@gmail.com
    within how many days i can solve my problem
This problem due to bad hard disk or some bad sector develop on it.repartion and than format (not quick format)and try.you may also run scandisk for surface scanning to locate bad sector.
Manish Kubawat ,India
mkubawat@yahoo.com
Posted on Oct 28, 2007
    Novelist:
  • 69 Answers
I am Vikram Kumar Thumu from India-Hyderabad. I have seen your message stating about error and also an issue with unable to install the Windows XP.
Well, such issues could happen due to below reasons,
1. BIOS Issue
2. if there is an issue with Harddisk.
To isolate the issue and resolve the issue I recommend you to try below steps as suggested.
1. Try to load the PC in to BIOS and try to check whether PC gets shutdown or not. I mean to say that, Get the PC in to BIOS screen  and let it be idle for 10-15 minutes. If PC does not Shut down in BIOS then it confirms there is an issue with Software side only and not with any Hardware Component.
  At this moment, there could be only three chances.
     a. With RAM
     b. BIOS software needs an update
     c. Windows Software
Now, once again load the PC in to BIOS, try to make the BIOS Default condition, In the BIOS , there will be Function Key by which you can make the BIOS default.  Example : For HP Laptops if we hit F9 key, it makes BIOS default in Notebook. Likewise, check out for Key and make it Default in ur PC.
Once if you are done with BIOS default please try to PC. If it still makes the issue. Then Power OFF PC and disconnect all Power cables from Notebook and try to RESEAT RAM Cards in ur PC.
Once if you are done with RAM, if it still makes the issue. Then I recommend you to Visit Web site of PC Manufucturer and try to update BIOS version. This might really work!!!
However, if the issue still persists then WE HAVE ULTIMATE SOLUTION to try WINDOWS RECOVERY CONSOLE
Please perform below steps to try RECOVERY CONSOLE:
Note**  Below Steps are applicable for only Windows XP.
To resolve this issue, use the Windows Recovery Console to extract a new copy of the Kernel32.dll file from the original Windows XP compact disc (The CD). To do this, and follow
these steps:
Follow these steps to install Recovery Console:
1. Start the Recovery Console. If you do not have the Recovery Console installed, start it from the Windows XP compact disc (The CD). Follow the a. b. c. d. steps to install Recovery Console:
a. Insert the Windows XP CD in your CD drive and restart your computer. If prompted, select any options required to boot from the CD.
b. When the text-based part of Setup begins, follow the prompts; you need to choose the repair or recover option by pressing R .
c. If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the recovery console.
d. When your prompted, type the Administrator password.
2. At the command prompt, type cd system32 , and then press ENTER.
3. Type ren kernel32.dll kernel32.old , and then press ENTER.
4. Type map , and then press ENTER.
5. Note the drive letter assigned to the CD-ROM drive that contains the Windows XP CD. It is displayed in a format similar to the following:
D: \Device\CdRom0
6. Type expand drive \i386\kernel32.dl_ (where drive is the drive letter of the CD-ROM drive that contains the Windows XP CD), and then press ENTER. For example:
Expand d:\i386\kernel32.dl_
Note the underscore character after the "L" in Kernel32.dl_
The following message appears:
Kernel32.dll
1 file(s) expanded.
7. Type in exit, after the computer restarts remove the Windows XP CD and start the computer normally.
This should resolve the issue. However, if the issue still persists then try to completely format the PC and then go ahead with Installation Of windows XP. For this you may need assistance of any experienced person whose has a sound knowledge on this process. Else you can Contact any service center near by....
 Note** Don;t worry this is not an issue with Motherboard.
This should resolve the issue for you.
 If you need any further assistance on the issue, you can mail me at thumuvikram@rediffmail.com . I'll be glad to help you.
Bye.
  • Vikram Kumar Thumu
    Vikram Kumar Thumu Oct 28, 2007
    One more thing to add, if you have a doubt on Hard disk, please try to load PC in to BIOS, and then locate to Tools or Diagonstics Menu and try to select the option Hard Drive Self test. This is a test that changes and reports the status of Hard drive by BIOS.  It takes about around 1 hour to test it. Try this, if the test passes then Hard-disk is fine, else if results in error then it as an issue with hard-disk.
    Bye.
Can i use core 2 Duo processor in my intel D101GGc Mother Board
Hi, the following link should help you with this question:
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-025906.htm
This gives a list of supprted processors for this motherboard.
Apr 12, 2011 | Intel D101GGC Motherboard
I am havimg a p4 processor.iwaan replace it by core 2 duo.will it be possible with D101GGC
This motherboard only supports the folloing processors.
  • Intel® Pentium® D processor 820, Intel® Pentium® 4 and Celeron® D processors in the LGA775 package
  • Supports Intel® EM64Tφ
  • Jul 07, 2010 | Intel D101GGC Motherboard
    Intel d101ggc original motherboard
    If it has a Pentium 4, 3 GHz CPU installed on the motherboard, than it is a 32 Bit Motherboard, and you can only use and run 32 Bit based hardware, and software on the computer.
    Jun 19, 2009 | Intel D101GGC Motherboard
    Mother driver Problem
    hello sir,
    even i have the same motherboard, you can confirm and even download if from the site given below:
    http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2229
    abhinav
    Jan 10, 2009 | Intel D101GGC Motherboard
    I need mother board drivers
    hi,
    ok download driver from the link blow:
    Thanks for your question
    Jan 03, 2009 | Intel D101GGC Motherboard
    Vista compatiable
    intel doesnt list any vista drivers for that motherboard on there site so you might run into problems with the intergraded devices such as the ethernet,audio,chipset, & any intergraded video
    You might be able to use the xp drivers but if theres problems it wouldnt be supported by intel
    Nov 26, 2008 | Intel D101GGC Motherboard
    Intel d845 gvfn display problem.
    sir i have a problemmy mother board intell d845 epi/d845gvsr my mother board is cannot desplayed or display is not come but if i remove rame the mother board is give error beaps if i attach ram board is not displayed
    Apr 25, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
    Intel Motherboard Logo
    218 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    Alun Cox
    David
    David
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
