Question about Kenwood KW85 Air Conditioner
Fault E3 - Kenwood KW85 Air Conditioner
  • 2 more comments
  • karel09 Nov 22, 2007
    Fault E3 ?????????????????????????????????????????????
  • wart0rn Jan 10, 2008
    Having the same problem. But there is no button mark "C".
  • Anonymous Jun 10, 2008
    que hago si no tengo el control como soluciono la falla
  • Anonymous Mar 31, 2014
    How can i removed the E3?I already charge r-22 freon but still A3 error.thank you
  • 236 Answers
Start the unit using the remote control, after that push the C button of remote control if C display at the unit then off the unit and plug out the power supply. Then plug in again and "on" the unit using the remote control.
Posted on Dec 30, 2007
No remote control
Posted on Jul 03, 2008
5 Suggested Answers
SOURCE: Error : E3 FAULT
WE HAVE PORTABLE AC SPT USA .This is a problem in display E3 FAULT
Posted on Sep 21, 2008
  • 86 Answers
SOURCE: kenwood deishwasher kdw243a
no idia
Posted on Mar 17, 2008
  • 521 Answers
SOURCE: Fault E3
it indicates the problem of a compressor as the fan works fine .i feel the compressor is not able to cool the device.i will suggest you to get it checked by a proper technician.
Posted on Aug 09, 2008
i have problem ac indoor come on display e3 error problem kindly give me solution
Posted on May 05, 2012
Model wf361. What is causing e3 error?
e3. Drive motor tach fault. This means that the tachometer is not regitering any motor movement when it should. Main reasons for samsung: motor control board fault. Tachometer fault. Motor fault. Also check wireing from motor control board to motor. But this issue is not common at all with samsung.
Feb 15, 2016 | Samsung Washing Machines
What is error code E3 in washing machine Beko 91242 LC
This error code is below. Good luck to you:
E3
Constant heat
Nov 25, 2014 | Beko Washing Machines
E3 Error Message
E3 indicates a sensor fail - most probably the humidity sesnsor. Or it could be a fault in the display itself. Are all the functions working properly?
May 28, 2013 | Humidifiers
Code reading E3 F-1
Thank you for using FixYa. F1 refers ro a fault with either the control board or touch pad. Both may need replacing to clear this error. E3 refers to a fault with the temperature sensor and should be replaced. This unless the repair done by yourself may work out expensive.
Sorry to be the bearer of bad news.
Mar 04, 2011 | Ovens
What is E3 code
Hello there:
E3 fault code
Touchpad or Software mismatch Flashes when there is a touchpad or software mismatch. NOTE: This error code is displayed only in diagnostics mode.
Unplug the machine for 30 min and then plug machine back in to clear this fault code
If the code persists the control panel is faulty and will need to be replaced or serviced by a qualified technician
Dec 16, 2009 | Maytag Washing Machines
Error : E3 FAULT
Sep 16, 2008 | Kenwood KW85 Air Conditioner
Fault E3 Have same problem, fan works fine but will not turn on cold air. Display shows "e3". I have a remote, but do not see a button "c".
Try this : Start the unit using the remote control, after that push the C button of remote control if C display at the unit then off the unit and plug out the power supply. Then plug in again and "on" the unit using the remote control.
Aug 09, 2008 | Kenwood KW85 Air Conditioner
No start
e3 fault??? sounds like an open sensor, located right nest to the thermaal fuse.
May 08, 2008 | Whirlpool GEW9200L Electric Dryer
Baumatic BDW13 14 dishwasher SHowing E3 Fault
word_answers.gif I had the same problem and changed the two thermostats on the base and got it working. You can get them from partmasters.co.uk (thermostat protector) cost 17.99. They just screw in and are dead easy to fit
Mar 08, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
Kenwood KW85 Air Conditioner Logo
1,182 people viewed this question
Top Kenwood Heating & Cooling Experts
Marvin
Marvin
john h
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
