Question about Dell E173FP 17" LCD Flat Panel Monitor
Dell lcd tv power shuts off several times
I have a 2306C dell lcd tv, it has been turning itself off several times while i was watching it. I was told that it was a transistor, that makes the unit think it is hot and shuts it off. I was also told that it was not in the power supply. If anyone knows which transistor is causing the tv to turn off, i could repair it myself. I need location number so that i can find the part that is bad and the part number. any help will be greatly appreciated.
Thank you,
Mr. Lorenzo
  • Anonymous Jan 13, 2008
    I too have the Dell W2306C LCD TV and it randomly shuts off while I am watching it. Is this a known problem with DELL?
    HELP!
  • Anonymous Feb 08, 2009
    I have the same problem with a Dell W3201C LCD TV. Would like to know if anyone has a home fix since this $1500 TV is 3 years old and out of warranty
Dell extended the warranty on these crappy LCDs - i had mine replaced a few months ago after it sat useless in the corner for a year. call them up, tell them what you have and they should replace it pretty easily/quickly.
Posted on Jun 20, 2008
If it is under warranty send it back if not, open it up you can usually smell a bad component inside a TV or monitor. also look at the ends of the component if they are dark in color you can probably bet that this is a good place to start.
you can also get a LED and a battery and hand test each part (if it blinks) you may question, you can also use a volt meter.
Dell buys there parts from china and some of the Capacitors and Rectifiers are cheap.
you can order these parts off the net for mer pennys or pull them from other electronics always research the numbers on the actual parts.
Posted on Jun 04, 2008
It shuts off 2 seconds after i power on.
Several possibilities but most common seems to be power supply defect or poor connection. Check these resources. Note that other Youtubes that may address the problem are also accessible from the youtube link.
LG Smart TV Keeps Turning Off then On Again
Lg Du 42px12x shuts down fix
42 in LG LCD TV turns off by itself
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
May 06, 2016 | LG 42LG50 42-Inch 1080p LCD HDTV
My 37 inch Sylvania TV model LC37SS9 M turned off by itself and to turn back on. I was watching dish network at the time
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 01, 2015 | Sylvania Televison & Video
When I was watching TV today my Sony Bravia KDL-40V4100 just swutched off by itself. After 15 minutes or so it came back on by itself, I shut it off soon after. Later on today after watching TV for 15...
When tv it shutting itself off by it own does the tv power LED light indication flashes?Tv turn on now,the tv power light indication,just flashes?Yes,than ur tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 12, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
When i turn on the tv , it shuts itself off in 2
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jan 31, 2010 | Sanyo DP26746 26 in. LCD Television
Tv turns itself off
Solutions?
Hope this helps
Mar 31, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Blinking light on 37" Dynex LCD
Solutions?
Hope this helps
Dec 22, 2008 | Dynex DX-LCD37 TV
Wow;;
It is very common that the power supply, and or the backplane lamps and lamp ballast supplies fail in LCD sets.
Jerry G.
Feb 14, 2008 | Dell W2600 26 in. LCD Television
Dell LCD TV powers on and after a few minutes shuts off by itself
Ok, this is the way how to examine where the problem is. You have to check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see something moving, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken. If you cannot see. I would say that there are some problems with the inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or dark spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Nov 08, 2007 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FP 17" LCD Flat Panel Monitor Logo
420 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
