1992 Volkswagen Jetta Logo
H
Hendrik Pretorius Posted on Feb 18, 2014
Starter wiring I have a 92 Jetta 1.8 A/T. The wire on the starter burnt off. DO you have a diagram to show how the wiring should go?
Larry Asselstine
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Jan 26, 2015
Larry Asselstine
Contributor
Level 1:
New Friend:
Answers
18
Questions
Helped
5360
Points
44
Was it the battery positive cable or a smaller wire. possibly a fusible link wire go online with year,model,and engine size of your vehicle and search for electrical wiring diagram even more specifically all wiring going to the starter motor
5 Related Answers
5LTRBTR
Kevin Blair
  • 196 Answers
  • Posted on Feb 12, 2009
SOURCE: 99 Jetta starter removal
http://forums.tdiclub.com/showthread.php?p=844411 this how to should work even if your car is the older style 99 they have the same layout for all 4cyl engines
Anonymous
  • 5 Answers
  • Posted on May 07, 2009
SOURCE: 98 jetta - won't turn over
very possible starter solenoid how do you know the starter is good
Anonymous
  • Posted on May 23, 2009
SOURCE: wiring diagram for 1997 vw jetta
Russan tech site
http://72.14.205.132/translate_c?hl=en&ie=UTF-8&sl=ru&tl=en&u=http://volkswagen.msk.ru/index.php%3Fp%3Dpage09_g3&rurl=translate.google.ca&usg=ALkJrhg0Wy_jBB-UJFE0G3M7MigPDiXv0g
Translation sucks but has some killer wiring diagrams
Anonymous
  • 208 Answers
  • Posted on Jun 22, 2009
SOURCE: VW Jetta starter problem. Automatic trans but the
faulty solenoid
Jonah Oneal
  • 14092 Answers
  • Posted on Aug 25, 2009
SOURCE: starter motor vw polo gti after long journey did
REPLACE THE POSITIVE BATTERY CABLE.BESURE TO BUY SOME FLEXIBLE WIRE CONDUIT.PROTECT WIRE FROM RUBBING CAUSING SHORT.ALSO REPLACE NEGATIVE BATTERY CABLE.DUE TO YOUR CAR BEING PCM CONTROL BY DISCONNECTING NEGATIVE BATTERY CABLE WILL CAUSE STARTING PROBLEMS AND STEERING PROBLEMS WITH NEWER CARS WITH ELECTRIC POWER STEERING.LET VOLKSWAGON DEALER REPLACE CABLES AND STARTER.
2answers
My 1998 dodge stratus wont start when i turn the key and their is a burnt wire smell and the wire is from the starter to a cilinode ? I think not sure do i have to replace the wire or the hole starter
Replace the starter. Starter is bound up and is drawing a lot of amps thus causing the burnt wire smell and wire to be hot.
This is a good video to help you diagnose the starter.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
I have a 92 mustang 5.0 and my starter relay fuse blew, where is it on the car I can't find it?
Here's the link to the starter relay.Here's another link to your wiring diagram,you have 4 fusible links at top of page,they all are coming from the positive battery cable,check them for burtness or swollen wires,replace with same gauge wire.To see if the starter link is burnt,get meter and put positive on positive battery cable at starter and ground black wire and have someone turn key,should say 12 volts or better.
1998 vw jetta gl if key is turned to the start position there should be a wire energized for starter (starter relay) right?
Yes, but don't get starter "solenoid" confused with starter "relay". The circuit should go from the starter switch to the fuse box, to the relay. Then the circuit will either go to the start solenoid or a secondary, larger relay. I am not certain about VW, but many manufacturers are using two switching relays in order to "step up" the load capacity. This is so the actual key-switch only has to control a tiny load, which makes it last longer.
If you do not have an open fuse link, it is time to find a wiring diagram. In my experience, I have always found that if one calls the service manager at the dealership, he/she is happy to provide a photocopy of a wiring diagram. The diagram will make it clear if there is one or two switching relays, and even what color the wires are and so on.
I hope this is helpful. Good luck.
Don
3helpful
2answers
1996 VW jetta will not start
You vehicle works off a standard ignition key which links to a electrical ignition switch. The wire from the switch goes to the starter solenoid. That wire has a fusable link which operates like a fuse. If to many amps surge through this wire it will melt down inside the insulation. The insulation will not melt away causing a headache to most novice mechcanics. Pull on the solenoid wire a few inches away from the solenoid and see if it stretches at least 1/8 of an inch or more. If it does it has an open stopping the continuity to the positive lug to the solenoid preventing it to work. Any auto parts store sells these fusable links. The counterperson will suggest the crimping supplies and tools needed to purchase for this repair
I have a 1990 toyota 4runner sr5! There is a black and white wire that goes to the starter that has power to it! Half way down this wire there is an encased diode or something and another wire comes up...
Check this wiring diagrams...
Fig. 23: Engine wiring-22RE 1989-92 4Runner and 1989-90 Pick-Up
Fig. 24: Engine wiring-6-cylinder 1989-92 4Runner and 1989-90 Pick-Up bf53123.jpg
Good luck.
1helpful
I HAVE A 92 BUICK LESABRE BUT KEY IN SWITCH TURN SWITCH NO POWER GOING TO SWITCH SIDE OF STARTER BUT WHEN I TAKE A WIRE FROM HOT SIDE OF BATTERY TO SWITCH SIDE OF STARTER AND KEY IN SWITCH TURN ON CAR...
You have no power from the switch to the starter. Check all you wiring that goes through the fire wall and look for burnt connections or just bad connections.
1helpful
2answers
I have a 92 chevy wagon and stopped to get gas turned the car off and went to start it and all it does is click one time. tried to jump it and didnt work. tried to tap starter and didnt work.
Check for a burnt fuse link Not the fuese but a fuse link, look at the positive cable going to the battery. Sholud be other wires hooked in the rubber end cap. These other wires are fuse links. feel them for a break or use a test light and probe them for power, repair the one thats burnt.
Can't find starter wire in 1992 GMC Safari Van
dose you truck have a coded key? (a chip in it?) if it does, your out of luck, the wire is ground switched and will not show anything on the volt meter. Instead, find the small wire from the starter and use that to make your connection
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
