Question about HP Pavilion F1703 17" LCD Monitor
Monitor goes into sleep mode
I have flat panel HP monitor that's only about 2 years old. for the past 2 days it has not allowed me to go past its "Monitor going to sleep" mode. I changed the keyboard and it came back on...now its doing it again...what can i I do.. Help!
  • 7 more comments
  • trish8941 Dec 29, 2007
    My Dell monitor is in sleep mode. I cannot get to windows at all. I only get touch any key or move mouse to disable sleep mode. But, that does not work. Does anyone have any ideas?
  • Anonymous Jan 22, 2008
    My son loaded Bioshock and could not get it to work. I downloaded Direct X9.0c and tried updating his NVDIA 5300 video card with downloads from NVDIA for the 8300. I was wiping his LCD complaining how dirty it was...all of a sudden...bam...don't know what happened...It keeps trying to start then quickly go into sleep mode. We can only see the screen for a few seconds, the hourglass on the mouse is running and I still see the Bioshock application open?
    Help?
  • ronjenks May 03, 2008
    same
  • Anonymous Jul 30, 2008
    My HP vp17 monitor goes to sleep mode one minute after I turn the computer on. It will come back on after I turn the computer off and on again, but goes right back to sleep mode in a minute.
  • DaGoose2 Aug 14, 2008
    Once My Hp W2207h enters sleep mode all I can do is reboot. Love the monitor but hate the sleep mode, Can it be turned off? Doesn't seem to matter what I am doing when it decides to enter into the sleep mode I can not stop it nor can I bring it out of the sleep mode with out rebooting.
  • drtaylor47 Jan 18, 2009
    i have the same problem,i changed monitors, same thing,, nothing, i disconnected the motitors power cord, and as soon as plugged it in, went to sleep mode, even when the computer was off, i also went and bought a new vidieo card, it didnt work
  • buster54 Feb 06, 2009
    i have the same problem. i cant get into my internet cuz keeps on saying in sleeping mode. cant pass that.
  • jimluhn Feb 17, 2009
    my monitor is going into sleep mode seconds after bootup
  • aweet05 Feb 17, 2009
    I have the same problem with my new HP LCD flat 17" monitor for quite sometimes & i thought i am the only one who has this problem. When "Monitor is going to sleep" appear, it is very disappointing because you can't on back the monitor in short time..Is it some kind of product defect? Really appreciate if anybody can settle this problem for us..
    Problem Solver:
  • 11 Answers
Just to check, do you have any power settings enabled? If you right click the desktop and go to properties, then screensaver, then power settings, look for hibernation and options to turn off the monitor after a certain amount of time. Maybe one of these settings got checked.
Posted on Dec 17, 2007
  • mav2541015 Mar 27, 2011
    that's fine if you could see what the hell you were doing miss, if you can't see anything, then i guess you're not going to know what settings you're in.
  • dev d Aug 25, 2011
    i have the same problem. with hp- L1506 s model..... if we do not see any thing on screen ..... and the CPU working properly.. then how to solve this problem .. I try by using another monitor ... as well as hard disk change and check that hard disk in to other system. May i know this problem we face only in WIN-7
U can not even see the desktop how do u go screen server. this happens before the operating system is even loaded
Posted on Oct 31, 2008
This has a mechanical fix. The problem is that the electronic connector to the monitor is, in varying degrees, a loose fit. The fix that worked for me was to clip the end of a straight pin about 3/8" (same length as the single pin in the electric connector), drop this "shim" into the hole in the connector, and then press the connector firmly into the bottom of the monitor. My monitor had been going into sleep mode immediately, every time - now it stays on. Only caveat is to remember this fix if you ever have to disconnect.
Posted on Jan 18, 2010
Had same problem...replace avg [video] board
Posted on Aug 14, 2009
It is a little hard to find in Windows 7
click the windows button in the bottom left
Chose "Control Panel" Then go to the "Hardware and Sound" option Then "Power Options"
In the light blue left half of the window Click "Choose when to turn off the display" Change it to "never" and save changes
Posted on Jul 16, 2010
Hello, I too had this problem. All it is ,is the sreen resolution. Turn on computer and keep tapping the F8 key to start computer in safe mode. once in safe mode go to programs, accessories, system tools and to system restore. Follow instructions on system restore by clicking next. On the calender click the blue date when you know the system last worked. Let the system retore. It will tell you whether it restored or not in the end. Then you will restart the computer as usual and not in safe mode....
Posted on Sep 09, 2012
Monitor go to sleep mode then sound of monitor speekar off why
Posted on May 13, 2010
    New Friend:
I have a computer with 3 monitors. I had the same problem - ended up checking all the stings (win 7). Just by accident found out that the powered MINI display cable that connects the monitor to the computer went bad. Those little cables are expensive but could be even defective from the start. The monitor even turns on for a few seconds or sometimes for a few minutes and then shuts off. Replace the cable!!
Posted on Jan 25, 2014
I solved this problem by going into "Control Panel" and then "Power Option" then clicking on the side, "Choose when to turn off the display" and then it was set to "20 mins" so i changed it to "Never" Hope this Helps. Rajetharan
Posted on Jun 23, 2010
  • HP Master
  • 3,114 Answers
Wmhanko119 wants more answers to this question
hy jacker to 2007 post wants information
why not start you own post.
with.
  • what PC, and OS, (windows XP:?)
  • what monitor F1703 17" LCD Monitor
  • did you push the 1703 menu button and turn off the silly sleep timing inside first (covered in the free manual this is)
  • did try a more modern monitor 2010 or newer on this PC to see if the PC is oK first,? seems now.
  • did you test the 1703 on a known working PC first to see omg it is the monitors problem only, no yo did not. but can.
we have posted this answer for old 2000 2010 monitors vast times here, endlessly...... search much
Posted on Apr 27, 2018
I had same problem. Nothing is wrong with the monitor itself as it will work with another computer. The actual problem is configuration of the power options, but there is no way you get to solve it, except to reset to factory default with a setup disk.
Posted on Aug 21, 2010
Trust me what every u do it wont work
I just open my computer and swith the memory thing
it when your computer full of stuff and virus
Posted on Feb 12, 2010
  • bkbatman Feb 12, 2010
    The problem is it not your video card it your computer is the problem the computer is like the brain to all function of your screen, either,mouse,sound,everything
4 Suggested Answers
viziks
  • 220 Answers
SOURCE: HP Monitor goes into sleep mode
Problem of monitor sreen going black in 5-10 secs is generally dry solder joints around the inverter transformer on the inverter PCB.
Posted on Feb 19, 2008
  • 6 Answers
SOURCE: HP vs 19 Flat Panel LCD Monitor will not turn on.
I too have an HP vs19 lcd monitor that the power stopped working around 18 months of use.
I have been searching trying to find a website that maybe someone had taken photos of their repairs on these vs19 lcd monitors.
Haven't found a site yet.
I would like to know before I attempt to open up the back of my monitor, the capacitors you are speaking of, are these soldering or do they just plug into the power board?
I'll be hitting the radio shack to see if I can get these capacitors.
Posted on Oct 09, 2008
  • 7 Answers
Find instructions to fix a problem like this here:
http://boredprojects.blogspot.com/2008/06/hp-vs19d-fix.html
It's helped a lot of people so far, hopefully it will help you too.
Posted on Jul 13, 2009
How do i get my hp w2007 monitior out of sleep mode
no PC stated or OS.
is this VGA, DVI or HDMI?
guess VGA. and its matching cable.
there are 2 sleeps, on old monitors.
the PC sleeps the monitor by disabling the 2 sync,. wires
HORZ and VERT,
the display shows, NO SIGNAL when this happens.
2008 (your monitor is 2008 , can be)
older monitors , have built in sleep, called also power saver TIMER. (push menu button on monitor)
read page 4-5 in your free HP manual.
PDF page 31.
http://h10032.www1.hp.com/ctg/Manual/c00834092
(aobut 1/2 do not have LED back lamps this year)
also this monitor has CCFL back lamps that by now
all go: most are dead now, used every day 8 hours per day.
1: dim
2: yellow
3: dead
4: or works 1 day , minute or week then not. (random)
if the pc tests ok on newer monitor, then its not the PC
if the Monitors fails on other PC , turn off power saver inside.
if the CCFL is dead, shin a flashlight on the screen, see data.?
if yes, the CCFL lamps are DEAD. (now or soon or whenever)
Mar 25, 2018 | HP Computers & Internet
HP LP2065 MONITOR goes to sleep
Hi There The Monitor setting you set through the computer, may you select the sleep mode or hibernate. Chang the mode and fix the problem.
Thanks http://pacificbits.ucoz.com/
May 08, 2012 | HP Pavilion F1503 15" LCD Flat Panel...
Hotmcompaq 7020 monitor will often display the following when turned on... the 'title page' showing Compaq. Then a rectangle shows up that says "searching for analog signal" then few...
That is the OSD brain, inside said monitor
The On screen display , window.
push the menu key on said monitor, see that MENU now?
sure. that tells you the monitor is basically OK.
that message means the unstated PC, is not sending any video or sync signal (or its cable is bad or unplugged or loose)
or the funny timer is tripping.(out)
monitors evolved like 5 times from year 2000.
so first i carbon date yours, to see what you actually have.
FP7020 is not a TFT7020, got it.
i wish i could read the service tag on it so i can be accurate but i cant.
no matter both are now RETIRED. at HP (hp is compaq , a fact)
https://support.hp.com/us-en/retired-products
Zero support now... no books, no nutt'n!
the first monitors, had a timer inside, and a clock that had a auto sleep mode, inside it, yah. they did, and is a pain .
lacking the book , one cant know that can one.
seems its 2002 carbon dated. wow 15 years young , ouch
this is the year the VESA rules went in to effect.
long ago, and changed 4 more times. dig>?
found a 15 years old product sheet on this old display
shows"internal sleep timer" yup, I just knew it was there,....
first make sure its off. (this must be OFF)
if its on and the clock inside is set wrong, it will trip off , at odd times.
let me explain back in the dark ages of monitors.
they had many PC that had no sleep mode
so HP(old compaq) put a clock(time of day) and sleep timer in dislplay., (for US gov, energy STAR bs)
so what you do is first set the OSD clock to the correct time.
then in the same menu system turn off the magic clock.
magic is that only this old junk has this display
or
test the monitor on another pc to see if its monitor issues or not.
lets not say , the monitor , is ok, and its funny INANE sleep timer is shut off.
what next, well the PC is next.
but wait you never told what PC, ?
so it can be any of 10,000 different models , VGA cards, chips and OS.
endless possibles for 36 years of PC evolution.
hopeless on my end to speculate.
NOr did you say what OS you are running.+
All PCs shipped new have shipped with sleep turned on in windows
or is this running OS2 or LINUX.
in WINDOZ
click control panel
there click power settings
there, click custom settings and give it a name, and then pick
NO sleep, no Hibernate at any time.
then turn off screen savers if on. most are off default.
when the PC wants to sleep it stops the Sync lines on the VGA card
or GPU chip.
the monitor sees that and goes to sleep. all do.
if the card is bad, its bad.
if OS is corrupted reload it.
if the PC runs ok on other monitors you cable is bad.
if the cable is ok the and PC is ok, then the monitor is bad
simply move the monitor to other PC
simple move pC to other monitor, and 1/2 the possibles are now know... in 15 min work, about.
Jun 24, 2017 | Compaq FP 7020 17" Flat Panel LCD Monitor
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did'nt.....blue power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
http://www.pcdied.com/monitors.html#flashlighttest
Jan 12, 2018 | HP Vs17 17" LCD Flat Panel Monitor
HP w1907 LCD Monitor goes to sleep by displaying a "monitor is going to sleep"error after turning on the computer and doesnt display anything. It works intermittently, in that, if the computer has been...
so if you test the monitor on a known good PC it does what?
fails, then its the monitor
works then its the failing PC
all old HP monitors pre 2010 many had a sleep timer
so push the menu key on the monitor
then look for sleep timer and turn it off,
the monitor defaults to that mode, so dont push reset monitor or bam back to sleep mode it goes. so turn it off again.
all this is in the manual, lost yours, wana read it first?
read page 4.7 see that? (osd +advanced +) power saver OFF
https://www.manualslib.com/manual/418165/Hp-W1907-19-Lcd-Monitor.html?page=25#manual
if that fails to fix it (tested on 2 PC ) the PC1 is bad.
that be a whole other WALL OF TEXt, ask.
Dec 10, 2017 | HP w1907 LCD Monitor
HP 2338H Monitor Goes into Sleep mode and I have to power comput
you meant w2238w , right, you left off the w?
circa 2006 monitor, 11 years old.?
if the monitor fails on 2 PC, the monitor is bad ! ok, do that...
then
push the monitor menu buttton, connected to a running PC.
if the OSD is dead, , (on screen display , menu button front of monitor)
that means the monitor is dead, CCFL tubes are bad.
cold cathod florescient laml tubes all day this old.
the menu button can be in lock mode, hold the button for 10 seconds, and it unlocks
then go in the OSD screens if they work,. and turn off the sleep timer.
this timer is marked in the OSD as power saver,. turn it off.
it is a time clocked feature, and a pain to use on modern PC.
your PC does sleep modes today and never us this timer,inside monitor (default is on, turn it off)
all that is on page32 in your manual,
https://www.manualslib.com/manual/71500/Hp-W2338h.html?page=32#manual
Sep 21, 2017 | HP Computers & Internet
Please look at the video card of your computer,did you set it correctly?
Apr 01, 2009 | HP Vs17 17" LCD Flat Panel Monitor
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
Monitor stays asleep
Check in the BIOS and see what your monitor settings are.
Did you change the sleep mode or power off mode? What do you do to make it come back on? Sounds like it might be getting too hot and/or going bad. Try it on another machine and see what it does. Also try another video card because the video card could be going bad.
May 30, 2008 | HP vs15 15"LCD Flat Panel Monitor
Oct 29, 2007 | HP Pavilion F1703 17" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
23,739 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
