Question about Samsung Digimax S800 Digital Camera
When I try to turn on, or see pictures stored, it beeps three times and shuts off
I turn the camera on with the power button, or with the review button and it does nothing except the power button lights up and it beeps three times, then the power light goes off
  • Anonymous Nov 11, 2007
    the lens wont go in when i turn it off, and the screen sometimes turns 2 different colors which are usually black and tan. i have pressed every button but it wont turn off or on and i cant view any pictures. we dont want to get it professionally fixed because it costs too much.
  • Anonymous Apr 07, 2009
    I turned on the camera and it beeps, then goes off. I have replaced batteries, and put in a new memory card. Nothing has changed.
Called samsung s800 have know power problems return for replacement before warranty expires or they will charge you 58 to fix
Posted on Mar 11, 2008
Camera lens is stuck in out position, but screen is not on, beeps three times when i push the on/off button
This may help: connect the camera with the charging cord.
press and hold the ON/OFF button and the PLAY button.
(the one that allows you to see the pictures you just took).
hold them until the light on the charger cord starts flashing and then the screen turns on and the lens retracts.
Mar 16, 2017 | Samsung L100 Digital Camera
Camera turns off when taking picture
Try changing the battery brand and see if this helps..I seem to have the same issue with my camera with certain battery brands..Solved my problem by switching brands..
Jun 21, 2008 | Fuji FinePix A345 Digital Camera
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
EX-510 Powers up, them immediately shuts down
I have the same problem is there a fix?
Jul 12, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Camera turns on then immediately shuts off
I have the same problem - 4 fast beeps and it turns off. My guess is that the lubricants are getting old and sticky - I had a Canon SLR that developed the same problem after being in the extreme cold. Here's a couple of things to try:
  • You can still access the picture review features by holding down the review button while you turn it on (note that if you hold down the trash button you'll see the firmware version.)
  • What doesn't work: Resetting the camera from the setting menu; replacing the battery, replacing the SD card, cursing.
  • I've been able to consistently get it to function normally by hitting the camera into the palm of my hand on the left side (with the viewing screen facing you), just after turning on the camera.  If this doesn't work, keep hitting harder until it works.  Once on, the camera works normally.
Aug 16, 2008 | Pentax Optio W10 Digital Camera
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 29, 2008 | Pentax Optio M20 Digital Camera
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Camera keeps shutting off
Have you fully charged the new batteries
Nov 03, 2007 | Fuji FinePix A345 Digital Camera
The lens doesnt close and when i turn the camera on it bips three times and the screan shuts off. the lens wont close.
The batteries need to be changed. The digital batteries sold at the stores die out too fast. I had this same problem. In result, I purchased rechargeable battieries.
Nov 19, 2006 | Samsung Digimax S500 Digital Camera
The Polaroid Fun! Digital 320 camera is programmed to shut off automatically after a few minutes if it is not being used. This helps to conserve battery power. When the camera shuts itself off, it will make a continual beeping sound. To use the camera after it has shut off, simply push the shutter button or self-timer button to take a picture. If you are not going to use your camera, turn the power switch to OFF. The camera will also beep in rapid sequence after you press the self-timer button. The camera will continue to beep in faster sequence until a picture is taken (approximately 10 seconds). A final long beep signals that a picture has been taken. NOTE: It is normal for the camera to beep while downloading photos to a computer.
Sep 14, 2005 | Polaroid PhotoMax Fun 320 Digital Camera
Samsung Digimax S800 Digital Camera Logo
351 people viewed this question
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
