I have a Kenmore top loading washing machine. No matter what load size I choose, the water keeps filling and doesn't turn off to agitate. Overfills the drum and leaks out the bottom. Before this problem I had added items to a load that was stopped mid way through the beginning of the agitation in the cycle. Can I reset the machine somehow?
Grab the tube off the water level switch that comes from the bottom of the tub and blow it out so that the sand in the bottom won't be blocking the operation,pump out the water, secure the tube tightly to the pressure switch and retry.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Check water valve not shutting off.
Check water level switch , or hose going to it from tub could be leaking must be air tight.
