Question about Canon PowerShot S2 IS Digital Camera
Canon S2 IS
The Camera dropped off and after that the lens comes out but after some delay and some grinding noise.
    Novelist:
  • 164 Answers
The lens needs a professional camera repair service.
The probability is high that the ultrasonc lens motor or th lens internal gears are damaged, and needs replacement.
Best regards,
Posted on Jul 22, 2009
My lens won't go in and when I try to take a picture it clicks and the code E18 comes up.
lens error comes when your lens is not able to retract insde.
This can be due to some kind of dirt or any sand particles stuck inside the lens. this may also occur when the camera is dropped from a height which damages the lens system.
Please give a small tap to the camera lens. It works in many cases. If not you will have to consult a authorized service center
Jan 03, 2011 | Canon PowerShot S2 IS Digital Camera
Canon Powershot S2 Is
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Jan 11, 2010 | Canon PowerShot S2 IS Digital Camera
Lense is extended but will not retract combined with a clicking noise....error code E18
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jul 23, 2009 | Canon PowerShot S2 IS Digital Camera
Canon g9 Camera was dropped. Now lens will open but not extend and motor to move lens makes a grinding noise. Is this repairable?
Yes it is the lens is exspencive but it canbe replaced. cost on the lens is about 150.00 for parts and labor. could be more or less at other digital camera repair shops.
Jun 26, 2009 | Canon PowerShot G9 Digital Camera
Canon Powershot S2 IS Disassemly guide?
Here are some things that you can do to try to correct it without disassembly. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 22, 2009 | Canon PowerShot S2 IS Digital Camera
My Canon Power Shot S2 1S will not take pictures because the lens will not go back in or out. The screen is black unless I review recent pictures
Do you get an E18 error? If so, then the lens motor is bad, or you have contamination in the gears (sand, dirt, etc), or mechanical failure from dropping the camera. This will require repair by Canon or other camera repair services.
Jan 17, 2009 | Canon PowerShot S2 IS Digital Camera
Canon powershot s2
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Feb 01, 2008 | Canon PowerShot S2 IS Digital Camera
E18 Error
This is due to a jam. This camera has had many problems with the lens There has been a problem.
I'm sorry but your only choice is an exchange or refund.
Hope This Helps - Josh
Dec 29, 2007 | Canon PowerShot S2 IS Digital Camera
I dropped my camera
If you still need this camera repaired, I can perform the fix. Does it still operate normally otherwise?
Oct 31, 2007 | Canon PowerShot S2 IS Digital Camera
My lens won't come out.
It sound like the lens mechanism was damaged during camera's drop. Only way (to my regret)is to sent it to be repaired in a professional lab.
Dec 03, 2006 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
99 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
