Question about Microsoft Xbox 360 Console
Bottom right ring light flashing red and E 74 appears on the screen.
2 year old system,dissembled & cleaned yesterday. Always ran additional external triple fan.called x-box $100 to repair.They said no longer under warranty.How long is warranty supposed to be & what specifically should I check on the board?? No hot spots or visual shorts noticed and no cooling fan failure. Tried a known good av cable set and power supply and the same error came up. Have access to local tech help if pointed in the right direction. Any suggestions would be greatly  appreciated. Thanks much.
  • yukonpete Dec 12, 2007
    Thanks for responding.The error was E-74. I then got the three rings error. I actually sent in to microsoft and they said they would not repair beacause it was tampered with. It was tampered with to get cleaned. The problem is the overheat issue which should have been repaired.They sent it back without even asking if I wanted it fixed.Can you tell me what E-74 error is? Can you list what the errors call out?The three rings error is covered under a three year warrenty now through microsoft but do not open box if you want it fixed. Thanks much, yukonpete.
You can easily fix this with an XBox 360 Repair guide from http://3RedLightFix.com
Posted on Dec 12, 2007
    Scholar:
  • 85 Answers
There are a ton of errors that can occur what error did you get E45-E79 there are about 15 total errors for the bottom right light flashing but generally it is Hardware failure. Could be DVD drive Hard drive. Would help more if you havd some numbers or something.
Posted on Dec 11, 2007
  • Anthony Dec 12, 2007
    This is the known issue with E74. A few things could be wrong with your system.
    E74: AV cable error... There is a problem with the AV cable, try using a different AV cable. If the cable is known to be working then there is a 90% chance it's a scaler chip problem (the "ANA" or "HANA" chip connected directly to the AV cable) in rare cases it is the GPU.
  • Nate Bennett Jul 20, 2011
    what is av cable?
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
One flashing red light e-74 appears on the screen help
If the Console is still under 3 years old and Hasn't been Tampered, Modded or Opened then you can send it off to Microsoft to be repaired for Free
Dec 24, 2009 | Microsoft Xbox 360 Console
E-74 red light on bottom right corner
sounds like the red ring of death, contact xbox as they give u a 3 year warranty on this, they will pick it up and return it fixed.
Aug 07, 2009 | Microsoft Xbox 360 Console
READING SYSTEM ERROR E 74.
THIS IS LINKED with the £ red lights, or the red ring of death, so as long as its not 3 years old, Microsoft will repair it in the 3 year extended warranty, so head to xbox.com/support and get a repair, should take about 1-2 weeks.
Jun 07, 2009 | Microsoft Xbox 360 Console
Xbox360, i flashing red light bottom right error message
The cause of E-74 with one red light Error might be overheating of your console and for avoiding such error in future you need to put your machine at an open space. Ensure that it is placed near the window or you can also make some external arrangement for cooling of console such as cooling the machine through a pedestal fan.
But as your Xbox already have E74 with one red light Problem which can be solved by only repairing it, no other alternative.
Either you can send your Xbox to Microsoft (Please note that microsoft is no longer providing extended warranty for E74 with one red lightError) and wait for 3-4 weeks. If you don't want to wait for a month, you can also fix E74 with one red light problem with the help of this DIY Video, the guide will explain step by step approach to fix the problem. Choice is yours........
Apr 07, 2009 | Microsoft Xbox 360 Console
My xbox 360 has error 74
The E74 malfunction is a problem believed to be associated with the system's video output cables and/or hardware scaler chip. The problem involves unusual screen patterns, the appearance of an on-screen error message, and finally a flashing red light in the lower right quadrant of the power ring. When a system suffers from the failure the on-screen message reads "E74 System Error. Contact Xbox Customer Support."
You could send it in to Microsoft of you can follow the steps as outlined in this You Tube video.
Mar 21, 2009 | Microsoft Xbox 360 Console
Xbox
see this web page for your problem on red light
Sep 04, 2008 | Microsoft Xbox 360 Console
1 redlight flashes clearly red at bottom right hand side of the power ring,and 2 other dim red lights are flashing,only the 1 in the bottom right is bright though.it happened 2weeks ago but i tryed it...
Do you get an error message on your tv screen? 1 flashing red light means there is a hardware failure such as your DVD drive hard drive, dashboard error ect. Not much can be done about this issue besides having microsoft fix it.
Apr 23, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
386 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
