Question about Casio Exilim Zoom EX-Z700 Digital Camera
Pictures with White Lines
Hi - My Casio Digital Camera EX-Z700 has a problem. Whenever I take a picture, the image comes out with white lines across it or if I take a picture outside in the sunshine or in a bright area, the entire picture comes out white - there is basically no distinguishing figure in my photos - it looks like I took a picture of bright white paper. When you look through the viewfinder, or record a video the lines aren't there. What is wrong and how can I get it fixed? Please help me!
  • 2 more comments
  • joi90000 Nov 02, 2007
    Whenever i take a picture in the light the picture seems to be overexposed and has lines running though the picture... when i take pictures at night the pic seems to b fine but you can still see a little bit of lines in the background of the photograph! What do i need to do to fix this problem or can i send it someone to get it repaired!
  • Anonymous Nov 06, 2007
    I have the same problem with mine
  • 504dary Nov 12, 2007
    I have the exact same problem. Nothing works to fix it that I've tried...
  • Anonymous Jan 02, 2008
    same problem
Help,,also mine,,
Posted on Nov 21, 2012
I have the same problem. how and where did you get it repaired?
Posted on Jan 25, 2008
Same problem with mine!  Fine Any suggestions?
Posted on Dec 28, 2007
I also have this problem with my camera, was there ever a solution for this?
Posted on Jan 26, 2008
I have had my camera for not even a year and it recently started having this problem. Whenever I take a picture, the object will look fine in the display, but when I take the picture it gets horizontal...
If I understand you correctly, you're saying that the LCD display shows a normal picture when you are composing your shot, but that when you actually snap the shutter to record the shot, the resulting image has nasty lines across it?
That would indicate that the lens is fine, but that the image sensor itself or associated electronics have gone bad. If this is out of warranty, then you're likely out of luck.
Nov 26, 2010 | Casio Exilim EX-S5 Digital Camera
Casio exilim ex-z700
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
Can't repair by yourself.
It's need repair camera machine shutter.
more detail CASIO Exilim EX-Z700 overexposure
Aug 06, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Lines on the screen
pls try to chek if lense r working perfectly
May 05, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Casio Exilim Z700
Apr 30, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Overexposed photos in otherwise normal settings in casio ex-s500
It is the shutter (or at least it was for me) I found a simple test here: http://www.mydc.com.tw/repair/knowledge_en/casio-exilim-ex-s600-overexposure-t17.html
I repaired it myself, but it took me a whole afternoon and lots of patience.
The hard part is taking the camera apart, once I got to the shutter I just activated it manually so to dislodge any pieces that might have gotten jammed, then placed it back together again and it worked! :).
It's really hard to take apart, it's like a puzzle sometimes, to find which screws are keeping it together. I also had a bit of hard time when it came to put the zoom back together again.
But I guess it beats throwing the camera away.
I'm still puzzled on how the CCD works so that an overexposure would make horizontal overexposed lines, but everything points to that. Fixed shutter, lines be gone.
Apr 29, 2008 | Casio Exilim EX-S600 Digital Camera
White Lines and blurry Pictures
Mar 23, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Need Help!!! Please...
Sounds like a setting try setting it to default un the setup menu if that does not help then the CCD need tobe replaces most likely. Hope this helps.
Mar 10, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
Blurry white image when pics are taken during broad daylight
Try first to reset your camera. Press the menu button, go over to setup, go down to reset, press the right arrow, highlight reset and press set. Don't worry it won't erase any of the pictures on your memory card. If that doesn't work you can try and manually set the white balance on your camera and I would recommend sending it into repairs if that doesn't work since it's taking nighttime pictures fine. :)
Dec 07, 2007 | Casio Exilim EX-Z55 Digital Camera
White lines, all white pictures
I have the same problem have you been able to fix it ?
Sep 23, 2007 | Pentax Optio M20 Digital Camera
Casio Exilim s500--horizontal lines in picture and autofocus creates blurry pics
This is a CCD failure. Go to the Casio Tech support team. There has been an issue with a batch of CCD's and a recall on certain models of all makes This may be one of them
Jul 16, 2007 | Casio Exilim EX-S500 Digital Camera
Casio Exilim Zoom EX-Z700 Digital Camera Logo
489 people viewed this question
Top Casio Cameras Experts
pontelemon
pontelemon
Starnley Johnwells
Starnley Johnwells
Are you a Casio Camera Expert? Answer questions, earn points and help others
