Danby DDR586R Dehumidifier - 58 Pints Dehumidifier
Problem for Danby DDR586R Dehumidifier - 58 Pints Dehumidifier
Water will not go down drain tube
By dbolvin on Jun 10, 2009
Water barely (I mean barely!) drips down the drain tube which goes into my stationary tub. the dehumidifier is on a level shelf above the stationary tub. there are no kinks or anything in the hose. The tank STILL fills up with water despite the fact that I have the hose properly attached. What gives!? Very frustrated!
Solution #1
posted on Jun 10, 2009
Somewhat Helpful)
lkaarto
Rank: Apprentice
Rating: 75%, 1 votes
Sounds like you have a clog. Either try plunging the drain in the stationary tub or replace the line from the humidifer.. Just a thought
Was this helpful?
Yes
No
Popular Solutions for Danby DDR586R Dehumidifier -
Questions and Unsolved Problems for Danby DDR586R Dehumidifier -
Do you recommend Danby DDR586R Dehumidifier - 58 Pints Dehumidifier?
Answer
Answer
i recently had a brown-out and have had damage to a number of appliances. this occurrance blew the... (More)
Answer
how could i use my ddr586r dehumidifier because i lost my instraction
Answer
Danby Dehumidifier Model # DDR586R Serial # 6763858666 (only 28 months old) - Does not collect water... (More)
Answer
tank does not fill with water at all. How to adjust humidty levels? what does the temp grad mean?... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Danby DDR586R Dehumidifier -...:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1200
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
