Question about Microsoft Wireless Laser Desktop 4000 Keyboard/Mouse
Keyboard does not respond
Keyboard device says working properly, signal strength is excellent.  The keyboard just does not do anything.  The mouse that came with it works fine.  Checked all batteriers, drivers, etc.....
  • 7 more comments
  • Anonymous Jan 02, 2008
    Neither my keyboard or mouse work.
  • Danka Jan 02, 2008
    keyboard device says working properly, signal strength is excellent.
    the same problem... one more thing, the keyboard worked properly for one week... not it is not working anymore...
    we checked also the connection of keyboard with receiver...
    when is mouse working keyboard is not working and the opposite...
    thank you
  • fation Feb 29, 2008
    hi i have a big problem with my wireless keyboard its not typing none of the buttons work i changed the batteries and everything but the mouse is working but the keyboard aint and im using on-screen keyoard to type and i need a solution as quick as possibe and the keyboard had some problems when i bought it it kept freezing when i was typing i dont want my mum to find out because shes going to think that i done something to it but i didnt do anything to it and im going to get in trouble
    thank you
  • tigerpages Mar 01, 2008
    My MS Wireles Desktop 4000 keyboard is not responding at all and most times gives a keyboard error before booting up with or without the USB to PS2 adapter, so I am dead in the water. The wireless mouse that came with it is working. What I have already tried: Sofware is installed, I do see a steady green light on the receiver, I have held the channel button down after pressing the receiver button (thought not sure if that is the right way to do it, and the batteries have been checked/replaced. I borrowed a keyboard and have to use that for now, but I really want to make this ergonomic MS keyboard work as I have a cyst on my wrist that hurts with regular keyboard usage. HELP!
  • paks2008 Apr 03, 2008
    Same problem - followed factory instructions to install drivers -> USB receiver plugged in -> Batteries put in (brand new)
    Didn't work (both the keyboard and mouse).
    Uninstalled everything and tried again
    Didn't work (Both the keyboard and mouse).
  • baciarek77 Apr 18, 2008
    sameproblem
  • tommygunz77 Nov 23, 2008
    Exact same problem here with my Wireless Desktop Elite. Went to bed, it
    worked fine.Woke up the next day and it didnt work any more.
    The only thing that changed was an automatic Windows update.
  • webdork Jan 06, 2009
    I'm having the same problem with my MS Wireless Laser 5000 Keyboard. The mouse works fine. I changed the batteries in the keyboard but still no help. I tried everything I've read to help including updating the driver. I guess I go out tomorrow and buy a new keyboard. dang...not seeing anything that offers help.
    good luck everyone!
  • rjordan766 Feb 04, 2009
    I am sick of this keyboard. I get lot battery and low signal strength messages even with new batteries. I sometimes have to reset the connection half a dozen times a day. I love the keyboard's comfort but have had it with not being able to type. Mouse always works.
Same as solution 2 here my keyboard just stoped working i think it has some thing to do with the latest uppdates for vista that i downloaded other wise hawe no idea been down for 24 hours now
Posted on Aug 14, 2008
Erm guyz.... I need an urgent response on this one plz... So I bought this microsoft wireless desktop 5000 wich is just great... was! Two days ago, my mouse starting acting up... Basically, my mouse pointer doesn't follow the trajectory I draw up on the monitor... For example when I move the cursor from one side of the screen to the other, the arrow will stop at half the distance... Until then, I haven't installed any drivers, since this was working fine as a plug'n play device... After this, I also installed the driver, but it was of no use... I also attempted to re-establish the connection between the mouse and the receiver... No good.... Didn't change anything... Yet my keyboard works perfectly and all the batteries are fresh... Please guyz.... I am really desperate.... At one point the arrow wasn't moving on the screen at all though I was heavily moving the mouse...
Posted on Jan 17, 2008
Neither my keyboard or mouse, which is a Laser 5000 respond.
Posted on Jan 02, 2008
Did you couple the Keyboard with the receiver (press and hold on the keyboard)
Posted on Dec 27, 2007
Ok I just recently got the same problem AGAIN for the 5th time. Don't worry this is very possible to fix.
There are several ways in which you could fix this.
The number one suggestion that I would suggest is plug the USB receiver into a different port. (while the computer is off). Keep trying all your ports and make sure you press the connection button after each attempt.
If all is wrong and all USB ports seem not to work but you're signals are still strong...
Try this
*I would highly recommend trying to get into your windows desktop with the malfunctioning keyboard and the functioning mouse along with an extra functioning keyboard plugged in.
Turn off your computer and plug in an extra keyboard that will 100% work (i.e a cord keyboard)
Turn on your computer and follow this directory: Start -> Run -> devmgmt.msc
A device manager should pop up.
Now expand the 'Keyboards' section
The device should read the EXTRA keyboard name but that is not what you want.
What you want is for it to say 'Microsoft USB Dual Receiver Wireless Keyboard (intelliType Pro)' this is the name of your malfunctioning keyboard which is probably not there.
If that name is not there expand the 'Human Interface Devices' section
Scan the names and look for the icon that has a 'Yellow Exclamation Mark' meaning an error or a problem. Right click it and select properties.
Under device status, it should say 'this device is not working properly because its incomplete' or something along those lines. This generally means that while windows was trying to install the driver for your keyboard, a problem occured in the process of it.
To fix this right click the errored device and select uninstall.
Once uninstalled, select the action tab at the top and select 'scan for hardware changes'
If you have windows XP there should be several icon pop ups on the bottom right of your screen saying a device has been successfully installed etc. Which means only one thing. Your keyboard now works.
As extra... you can see your device now installed by expanding the keyboards section or opening microsoft keybaord intellitype and selecting hardware.
BTW my operating system is windows XP 2000
For extra help you can contact my email at stevenha1992@hotmail.com
Posted on Mar 01, 2009
Tower turns on but screen says no signal?
Check to be sure your monitor connection needles are seated properly. Is mouse wireless or connected to back of tower?
Jan 02, 2014 | Acer Aspire X3200 PC Desktop
Help with my Logitech keyboard and mouse. I only have the keyboard and the mouse do i need anything else to get start?
You need the wireless signal receiver. Cordless mice and keyboards send out a signal that needs to be picked up by your computer. Most of these systems plug into your USB. Here's a photo: moondogwst75.jpg
It should look something like that device on the mid-right side of the photo. That device will pick up the signals. It plugs into your USB. I hope this helps!
Apr 12, 2011 | Logitech Cordless Desktop MX3200 Laser...
The light on the transmitter is no longer on, but if I put it close to my keyboard and mouse, they work fine..Is there a battery in the transmitter that controls the signal strength??
The light doesn't need to be on to work. the lights on the transmitter indecate if the number or cap lock is on or if the mouse or keyboard batteries are low.
Mar 02, 2010 | Dell Wireless Keyboard Optical Mouse w0147
Signal strength has fallen from excellent to very low. strength on laptop and desktop pc remain excellent. Sounds like a NB100 glitch, but what?
As i understand your concern that on your laptop and desktop pc you are getting excellent signals so it might be possible that your third device required to upgrade the drivers for that. Because sometime it happened that the device driver not working properly.
Oct 27, 2009 | Belkin Computers & Internet
Keyboard not responding
Have you tried a USB keyboard and mouse wired.try also to hook up the normal keyboard and Mouse with out any usb devices hooked on the computer
May 05, 2009 | Logitech 967461-0403-PK Keyboard/Mouse
Compaq presario sr2150nx keyboard and mouse wont work
maybe the devices are both defective or you mistakaly plug it to the wrong ps2 port.check its pin.
May 05, 2009 | HP Compaq Presario SR2150NX PC Desktop
MS Notebook Wireless Mouse 6000
The part that goes into the USB port is the mouse receiver. If it has a button on it, press it and then tuen your mouse over and press the button on the bottom of your mouse. This is the reset/connect button.
Hope this is of some help. Bud
Aug 14, 2008 | Microsoft Wireless Notebook Optical Mouse...
Wireless Keyboard
Do you have any other wireless devices nearby? There could be interference between the different devices. Or as r_generato says, you might want to replace the batteries with new ones since reception distance is directly proportional to battery strength. Also, if you use rechargable batteries, they work at a slightly lower voltage and non-rechargeable, alkaline batteries will probably get better performance.
Feb 20, 2008 | Computers & Internet
Keyboard and touchpad
Have you attempted to use an external mouse? - USB - if so does that work?
if it does - Click on START - Control Pannel - Keyboard (& Mouse Respectively) - Click on the hardware Tab - Select the relevant Key Board, Click on Properties - this will give you a device status - if is is not working properly - click Trouble shoot & follow the onscreen instructions. - If is "Working Properly" click on Drivers - check your driver is updated, or roll back.
If you happend to be on a server and the keyboard and/or mouse have stopped responding - you will need to restart (The Server). Ensure that the Keyboard and mouse are on PS2 connections and not USB - the Severs do not like USB Connected Comms Devices. I have found if there are wireless mouse's &/or Keybourd's &/or any USB connected Mouse/Keyboard, they tend to somehow interfere with each other (i.e. the sever with one of the terminals) - only remedy I have ever managed to make work is restart.
Hope this helps
Feb 04, 2008 | Toshiba P25-S670 Notebook
open your iTouch configuration dialog box, cordless
tab, press connect, press connect button under keyboard.
should work. i have to do that every time i boot up...don't
know why...
Nov 11, 2007 | Logitech Cordless MX Duo 967300-0403...
Microsoft Wireless Laser Desktop 4000 Keyboard/Mouse Logo
869 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
