You need to get someone to do a code-read with a transmission capable scanner (transmission shop) You probably have a bad EPC (electronic pressure control) causing the transmission to slip, therefore setting a p1811 code (max adapt/long shift) which will max out the line pressure making your shifts very firm (but stopping the slipping/delayed shifts...this is a fail safe mode designed to keep your transmission from slipping until you address the underlying cause)
