Question about Dual XDVD-1002CM Car DVD Player
Dual XDVD1002CM dvd player remote needed
Hi, I got a used, broken, Namsung (Dual parent company) XDVD 1002CM flip down 10.2 screen DVD player reccently and have fixed it. Now I need the remote to be able to actually use it.
I know that there are universal remotes but I have not found one to work with this yet. I have tried several at this time, including units by GE, RCA and OneForAll.
I can get the remote to access the device using "code search" feature but not correctly. It responds to several different codes. When I check the codes I get a variety of Manufactures, and I get a variety of different operations for each. (on one the power button scans back a chapter, another the "2" button turns unit on and off, etc) This indicates that none of the universal remotes I have tried support this unit. It also proves the IR interface works.
So what I need is a source for the exact remote, a part number would do, OR, the model number of a universal remote that supports this device. I do not have the money,time or desire to buy additional remotes, hopeing that I will get lucky. Googleing for a solution has also NOT yielded any answers.
Help! Thanks, Ned
0 characters
1 Points
Lost the remote control for my XDVD 1002CM. Any ideas for replacement?
You can try contacting Dual or searching the internet for suppliers of replacement remotes
Oct 03, 2013 | Dual XDVD-1002CM Car DVD Player
Dual xdvd 8625 double din emergency brake bypass
you can ground it,then enter the code 26604 after u insert a dvd real dvd then press stop twice then enter the code it should work
Jun 06, 2009 | Dual XDVD8170 Car DVD Player
E- brake by-pass code
on the 9101 the enter button is ok make sure you use a real dvd no bootleg
May 30, 2009 | Dual XDVD8170 Car DVD Player
Dual xdvd8183 screen doesnt come out
hey i have a dual xdvd 8183 and my screen doent pop out but it plays and you an see that the screen is playing inside can anyone help
May 30, 2009 | Dual Electronics XDVD8183 Car DVD Player
This is the best bypass method for the Dual XDVD8181. Althoug i am not sure if it works for any of the similar models b Dual. My guess it will.
1) Groun the emergency brake wire.I used the radios black groud wire.
2) Insert a DVD and let it play until you hear the sound.Copied DVDS will not work for this.
3) Press STOP on the remote TWICE.
4) Using the remote enter 26604 and press enter .If done correctly you should hear it beep and the video will be viewable.Good Luck.
Mar 23, 2009 | Dual XDVD8170 Car DVD Player
How do i bypass the e-brake wire on this cd player
The principle is to ground the yellow/blue wire of the Dual XDVD8181 but with certain sequence and a few other actions. It is better explained with illustrations here while a pdf "how to" is available fro download here. User discretion with a consideration for safety pls.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 21, 2008 | Dual XDVD8181 Car Video Player
Dual indash radio xdvd-8181
Hey guys I have a xdvd-8181 indash dual radio and the password screen comes up and i forgot the password that i set it up with so i was wondering if there is any way to reset it??? Any help will be appreciated thanks Anthony
May 19, 2008 | Dual Bravo HRC-0703 DVD Package Mobile...
Dual XDVD700
How to get code for xdvd 700
Apr 28, 2008 | Jensen VM9510 Car DVD Player
Dual XDVD 700 Blank Screen
Take and bench test it. Pioneer brand do that when the ribbon cable is cracked. It is the one that get drag in and out during open and close. Open it up and check that. Goodluck.
Feb 05, 2008 | Dual XDVD8181 Car Video Player
Dual XDVD-1002CM Car DVD Player Logo
46 people viewed this question
Top Dual Car Video Players Experts
Sudeep Chatterjee
Sudeep Chatterjee
Brian Hogue
Level 1 Expert
Are you a Dual Car Video Player Expert? Answer questions, earn points and help others
