Question about Maytag Neptune MAH6700A Front Load Washer
Maytag Lat2600-fabric softener will not dispense
Have Maytag LAT 2600. After wash cycle fa bric softener is still in dispenser
SOURCE:
jsrock516
  • 5911 Answers
SOURCE: Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Posted on Feb 11, 2008
IFIXALL
  • 869 Answers
SOURCE: Automatic fabric softener dispenser does not dispense anymore.
replace the control board
Posted on May 26, 2008
SOURCE: Maytag Neptune FAV6800AW - Fabric Softener dispenser doesn't empty
I had a similar problem with the fab. softener chamber. Clean
out the buildup and it will drain. To do this, remove the cap and wipe out the softener. Also, be sure to wipe inside the drum, just below the dispenser.
As for a water flow to the dispenser- You will need to remove the plastic portion of the lid. Start with the detergent dispenser, then gently remove the bottom corners of the lid. Then are held by two plastic clasps. Then gently remove the "L" shaped plastic holders. Use a pipe cleaner to clean out the tube where the water flows directly out of the unit, before entering the lid. I did this last night, and it works beautifully!
Posted on Jul 19, 2008
dh1200s
  • 335 Answers
SOURCE: maytag neptune TL
The machine needs to cut you a break;
“”i have a maytag neptune TL and there are several things wrong with it...1. I can't wash small loads it will stop at the spin cycle and flash dc””
This issue is a clutch issue see this post to DIY the repair.
“”it will wash fine on regular loads until it comes to spin cycle again and it will stop and flash nf””
This one is a little confusing the “nf” error is a No water fill error code. Check these two post for support regarding water inlet restriction or valve not opening properly.
nf post nf post 2
“”my fabric softener dispenser will not let the softener out neither will the bleach dispenser””
See this fabric softer post for support. The fabric softener dispenser may be clogged or the water dispenser valves feeding both dispensers may not be operating properly. The Service Manual on page 16 “Board Output Test” will give you support to turn on the Fabric Softener Valve and Bleach valve. See if you hear the valves operate in Service Mode”
My method may seem a little confusion for viewing water flow to the dispensers. This issue could be associated to the nf error you are receiving, restricted water flow (inlet screen clog) or cold water valve not working properly.
Post back for any questions or possible support I can offer. I’m an owner like you not a repair person but I’m very comfortable working on this machine. Rich
Posted on Jun 17, 2009
GodBlessU
  • 3513 Answers
SOURCE: Maytag a112 manual on how to add bleach AND fabric softener
Hi
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
Bleach
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting fixya.com
Posted on Nov 13, 2009
The fabric softener drawer does not empty after a washing cycle so how do I solve this
It is normal for some water to remain in the fabric softener dispenser after the wash cycle is complete
Jan 10, 2013 | Washing Machines
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
The fabric softener dispenser does not drain. I have diluted the softener with warm water every time, still the fabric softener will not drain out. In the spin cycle the softener is thrown around the top...
The softener dispenser is supposed to get flushed during the cycle to prevent clogging. The flushing may not be happening in your machine and some residue could be clogging the discharge.
Nov 12, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Fabric Soft and Bleach despenser on MAYTAG TL FAV6800 won't drain
I'll see if I can help. Can you just clarify if by won't drain. Does it look like no water flow is flushing the the Bleach and Fabric Softener dispensers?
The Fabric Softener dispenser could be clogged but I suspect the dispenser’s valves are not opening to flush the dispenser’s. If the Fabric Softener dispenser is clogged you can flush with White Vinegar solution and clean exit port with a pipe cleaner. I do not suspect a clog with the Bleach dispenser.
You could go into Service Mode and turn on the water valves for the dispensers to check if water is sent to the dispensers.
If you have no water flow to the Softener dispenser here is the non technical troubleshooting I would take. Go into Service Mode (page 14 of the Service manual) by Pressing Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the console beeps.
Now go to page 16 to Service Manual and enter Board Output Test by pressing the Delicates key. This will lock the lid. Now press the Wrinkle Control Key Pad on the console. The Control Board will send 120VAC to the bleach dispenser water valve. Did you hear the Solenoid hum? If so and you have no water flow diverted to the Softener dispenser the solenoid valve may be stuck closed. If you did not hear the solenoid valve hum the solenoid field coil may be open. Do the same process for the Bleach dispenser water valve with Bulky Items Key Pad.
Final technical troubleshooting as a technical owner of the machine would be to take my DVM and verify 120VAC from the Control Board to the Bleach/Fabric Softener dispenser valves.
See page 36 lower left hand corner is the Bleach/Softener dispenser valve.
Here is the Service Manual for reference. Sears Parts Direct for reference.
The Part Number for the Dispenser Valve is 25001043 you can order from this site or search the internet for best price.
Good luck…….Rich
Mar 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune TL
nf post nf post 2
Jun 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
MAH8700AWW - No Fabric Softener
Not sure if you've ever resolved this issue, but I'm dealing with it myself. I have come across this service manual that gives a very detailed illustration of the systems, how it works and how to test it.
Focus on pages 15 thru 25. Hope this helps you.
http://www.servicematters.com/maytag_library/docs/16026126.pdf
Jan 26, 2009 | Maytag MAH6500 Neptune Front Loading...
Fabric Softener & bleach dispensing
The control board program has many sensors built into the unit to determine when to dispense the bleach and the softener.  LG tech documents doesn't list when these liquids are dispensed so there must be a program that matches the current operation and loads of each wash program.  That's the best answer I can give you at this time.
Jun 05, 2008 | LG WM2688H Front Load Washer
Feb 11, 2008 | Maytag Neptune MAH6700A Front Load Washer
Soap Dispence problem on GHW9200LW
In applications with low water pressure, insufficient water
volume is introduced during the fabric softener dispensing
portion of the cycle to flush the dispenser.
RESOLUTION:
The holes in the dispenser housing were enlarged to allow
a greater volume of water to flow through the fabric
softener dispenser to properly dispense the fabric softener.
Order and replace the dispenser housing, Part
#8181719, to correct the condition
Feb 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fabric Softner won't dispense
fabric softener goes into the dispenser. it may be a full blown solenoid valve -or- a flapper type of solenoid valve. operation of the solenoid operates a flapper to let the softener out. go to an appliance repair site to find the solenoid - appliance parts dot com or repair clinic dot com.
Sep 04, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH6700A Front Load Washer Logo
85 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
