Bunn CWTF 15-APS Coffee Maker Logo
A
Anonymous Posted on Feb 17, 2014
Carraffe overflowing It is hooked directly to the water source. It dispenses more water in the reservoir than the carafe will hold.
jasbo
Level 3:
  • Bunn Master 2,239 Answers
  • Posted on Jan 15, 2015
jasbo
Bunn Master
Level 3:
Answers
2239
Questions
Helped
991903
Points
5072
First, delime the sprayhead and the trough drain in the top with a flathead screwdriver to ensure maximum flow. next, you'll need a measuring cup or bucket that goes up to 64 ounces. then follow the instructions on the front panel
1 Related Answer
EsWorld
Ernest R
  • 1618 Answers
  • Posted on Aug 14, 2009
SOURCE: The Bunn CW Series overflows the pot. How canwe
Open the front panel, there is a set of instructions on it, you will have to make sure the board is set to program and not lock, before you adjust.
Water is not pumping up to the reservoir. If i manually put water in the reservoir it will make ice.
I just had the same trouble after connecting it to my new filtration system. Yes, if you pour water in with a funnel, it will make ice. You need to be wary of overflowing, as it will drip into the ice reservoir, so close the door quickly so overflow will come out the ice dispenser.
If Bunn unit has been stored for a while, how do i clean it and get it ready to use?
Hi, W/D here.
To get your Bunn working again, place a filter into the basket, fill the reservoir, and allow it to begin dispensing into the carafe. This will take several pots of water to get it filled and overflowing (dispensing). Plug it in, and let the reservoir heat up. It's not necessary at this point to have the heating plate turned on, but you can do so if desired to check that it is working, then turn it back off. Once you hear the reservoir heating up, pour in 8 ounces of white vinegar, and let the machine dispense into the carafe. Place an additional 8 ounces of white vinegar into the carafe, and pour back into the reservoir. Let the water heat up again, and let the vinegar solution sit in the reservoir for about 30 minutes. Top off the carafe with cool water and allow the carafe to cool with the warming plate turned off. After the 30 minutes, pour the contents of the carafe back into the reservoir, and it will dispense again. The water in the reservoir will heat up again. Check the coffee filter for residue. If you see a lot of grainy material, change the filter, and repeat the cycle until the filter comes out clean. Save your old filters as you go. Lay them out in order on paper towels, and you'll be able to mark your progress. When the filters clear up, discontinue recycling the vinegar solution and, instead, fill the reservoir with fresh water. The sediment has by now been freed up (de-scaled) and will continue to come off in smaller and smaller quantities. Each time you place fresh water in the machine, the dispensed liquid will smell less and less like vinegar. When no vinegar odor can be detected, you are finished.
Best regards, --W/D--
1helpful
Fabric Softener Dispenser Overflowing
Sounds like you have a blockage check/ clean remove dispenser to do
6helpful
2answers
Broke glass carraffe, need to replace model 169164
I replaced my broken carafe on model: 169164 by purchasing a RIVAL 12 cup coffee maker PIL-HC08104 from WalMart for $10.24 and simply put my black handles on the new pot whaic had white handles. The pot appear to be exactly the same.
3helpful
Cuisinart Grind and Brew will not emply all the water
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
1helpful
2answers
No manual with Bunn NHBX coffee maker.
before plugging in place your empty filter basket in the coffee maker and place a pot under it. Slowly pour in two pots of water using the pour pitcher. Now you can plug it in. it'll take 15 min to heat up first time . when you brew your first pot leave your water level a little short,because the water will expand (only the first time)
2helpful
Water overflow
If the water is running out the seams in the plastic BEFORE you brew anything, it is a defect or design flaw. I bought one that looks like the one pictured and it did the same thing. So did the replacement.
If the overflow occurs during brewing, verify the following:
Coffee overflowing onto the counter is a common complaint found in response to many automatic drip coffee makers. The following are potential solutions that can be used to rule out "operator error" vs. a defect or malfunction:
1. Do not "pack" or otherwise overfill the cone/basket with grinds.
2. Ensure you are using the correct grind for an automatic drip coffee maker, neither too fine nor too course. (See instruction manual.)
3. Do not overfill with water. Use the carafe to pour water into the reservoir. This is because a "cup" in coffee terms is defined as 6 oz, not 8 oz. Note: Some coffee makers define as little as 5 oz as a cup.
4. Make sure the filter cone/basket clicks into place and that the carafe is centered and pushed all the way in.
5. Try a permanent filter rather than a paper filter or vice versa.
6. Only use the correct permanent or paper filter (see manual).
7. Verify that the Pause 'n Serve button isn't sticking. If it is activated too long the brew will escape over the top of the cone/basket. This may be more apt to happen if the alignment of the carafe and the basket is incorrect.
8. Clean your machine with vinegar or as instructed by your user manual at least three times per year, more if your water supply is hard. A properly cleaned machine is less likely to suffer a burned out heating element, to take too long to brew, to produce "off" tasting coffee, or to clog and overrun the filter basket as the water runs through the grinds.
9. Ensure that the coffee machine is sitting level on the counter.
6helpful
2answers
Coffee overflows
I have a 1600 with the same problem. The problem is due to a poorly designed fit between the carafe and the drain plunger in the coffee basket. If you lift the carafe slightly, you will see the plunger has a long way to go. If you have the tendency to push the carafe fully to the back of the hotplate it makes this worse. OK, so now the fix, which worked for me. Find a small piece of plastic to glue to the top of the carafe lid. You just need a small dimple to push the coffee basket spring in further when you in sert the carafe on the hotplate. You should experiment a little first to see how thick it needs to be. Overall it's a poorly designed combination and someone needs a lesson in tolerancing.
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
