Question about Kenmore 44109 / 44102 Side by Side Refrigerator
Whirlpool side by side model number ED22GWXFN01
The fridge side is very warm on the highest setting. The freezer side is crazy. There are two vents, one at the top and another at the bottom. No air is blowing through the top but cold air is coming from the bottom and keeping the food frozen from middle to the bottom. I re-arrange the food daily to keep all of it frozen. Just can't afford a new one. Can you please offer suggestions that I may do myself, I follow instructions well. The purchase date was 9/1999 and there is no warranty. It stopped cooling about a month ago and I vaccumed the coils underneath the fridge side and it started cooling again. About a year ago I replaced a switch on top of the compressor that was burned out. Now this.  I have both sides on the highest settings but nothing has changed. I would be willing to call you if you provide me with a number. Thank you and have a blessed day.
    Scholar:
  • 146 Answers
Here's the deal. You probably didn't need the overload. Most likely you have a problem with your condenser fan motor. To check move the refer out from the wall and pull the cardboard panel at the bottom of the refer. Check to make sure the motor is running at a high speed. If not you will have to change it as there are no oiling points. If that isn't the problem open the freezer door and remove the back panel. Check to see if your evap. fan is running at high speed. Then check to see if your evaporator is iced up. If so either your fan is not running fast enough or your defrost heater is out. To check disconnect the heater and take a continuity check at each lead end you should register infinity. Which means your meter will peg itself over to the left side. If that is okay the only other thing that could be causing the problem would be the heater thermo which tells the heater when to come on. You will see it attached to the evaporator coils. Hope that helps. If so e-mail me.
Posted on Dec 18, 2007
Whirlpool side by side refrigerator freezer is warm and fridge section warm tap on thermostat and everything starts up and gets cold
What is the model number of your refrigerator? In most cases replacing a mechanical thermostat that begins doing this is the answer to solving this problem. Problem is I don't know what the type of thermostat yours has because you did not post the model number. Thanks, Sea Breeze
Apr 05, 2013 | Whirlpool Refrigerators
WARM FRIDGE FREEZER WORKING MODEL NUMBER, ART721 3XART721F01
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 04, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer is frozen fridge is warm
Your model is most likely the Profile Artica style. Most times the defrost heater is burned out behind the rear of the freezer wall. Manually defrost and look at the defrost heater to see if burned out. That model possibly has the glass covered defrost heater and will be easy to spot if burned out because the element is inside a glass tube, If you replace the defrost heater also replace the defrost thermostat, Please send me your model number located near floor of the fresh food compartment door seal and kick plate, Thanks Sea Breeze
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Hotpoint fridge problem, warm fride, but freezer working good
Fridge along bottom shelves is much colder than the very top shelf which has milk etc., leading to spoilage. Fridge is at highest setting. In the upper left rear of the fridge compartment, is a cover for what I believe to be a circulatory fan. However, trying to remove this cover is difficult.
It seems that the clip nuts to which the two (2) small capscrews fasten are free wheeling and not allowing me easy access to the motor.
Please advise.
My model no. is HSS221FMD WW
Jul 20, 2009 | Hotpoint HSS25GFP Side by Side...
Freezer suddenly stopped freezing and fride is not getting cold
Hi, I would try putting your refrigerator and freezer control switches on medium. Good Luck,I hope this helps you out.
Nov 07, 2008 | Whirlpool Refrigerators
Kenmore 44109 / 44102 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
