FixYa.com
Tags:
Dacor ECS127 Epicure Electric Single Oven
Oven not heating (by 6 users)
posted by toshietai on Oct 28, 2007
All control lights work, including the pre-heat 135 degree light, but the oven stays cold.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by cshwillis, posted on Jun 24, 2008
I have a MCS127S Dacor oven. Turned it on to cook dinner last night and it will not heat. Light comes on at 135 degrees, but will not go above this temperature. Have not had self-cleaner on. Have pushed the cancel/secure button and held for 3 seconds, and have checked that time is correct. Any other suggestions????
Comment by donshafer, posted on Jun 07, 2008
I have exactly the same problem. Just used the oven a day ago to broil and bake. Today, it will not heat at all. And, will neither broil, convect or self-clean.
Comment by dacor dan, posted on Jun 02, 2008
Broil setting conked out and oven won't heat above 140. What's up with that?
Comment by Guest, posted on Dec 04, 2007
We put our 3 yr old oven thru the self-clean cycle and now we can't get it to heat up on bake, boil, convection, etc. Is there a manual reset button somewhere?
Comment by icre8, posted on Nov 06, 2007
We have owned this oven for about 7 years. In that time, we have replaced the mother board/control panel 3 times, costing us a fortune. We also had the light strobing problem and when it was finally fixed, the two halogen bulbs $45 each were burned out. Dacor was no help. Now everything seems to be working properly, but the oven will not heat up. We are ready to chuck it out the window.
Best Solution
posted on Nov 05, 2007
FixYa! (100)
jeweljtr
Rank:Apprentice Apprentice
Rating: 97%, 3 votes
i have had this problem twice. once was the heating element actually had shorted out because the little ceramic holders had broken, this necessitated getting new element. can be checked out with an ohmmeter by yourself or by taking element into appliance repair place. the other time, it was that the manual reset switch had tripped after a self-clean cycle. actually at the moment, that has happened again- design flaw perhaps in the RSD30 range?
so anyone who can tell a reasonable competent refrigeration/HVAC technician where the manual reset switch is would be appreciated.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Ovens problems?
Resetting Dacor Oven
Did you ever find that reset? Answer This...
dacor single oven
code "u60 cooling... Answer This...
Epicure ECS127SCH gas wall...
I need information on how to... Answer This...
Dacor error codes
My Dacor single wall oven won't... Answer This...
no lights or operation
I've got a problem where I'm... Answer This...
Repair Service
Find Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
